Ga door naar hoofdinhoud
Zeki Droid Tablet Camera Replacement
Wat je nodig hebt
  1. Zeki Droid Tablet Camera Replacement, Back Casing: stap 1, afbeelding 1 van 1
    • Remove the back casing by slowly popping each tab out with a plastic opening tool.
  2. Zeki Droid Tablet Camera Replacement: stap 2, afbeelding 1 van 1
    • Remove the tapes one by one from the connecting wires with tweezers.
  3. Zeki Droid Tablet Camera Replacement: stap 3, afbeelding 1 van 1
    • Remove the black clips from both sides of the casing with a plastic opening tool.
    • The clips should pop off separate from the speakers.
  4. Zeki Droid Tablet Camera Replacement: stap 4, afbeelding 1 van 1
    • Remove the speakers from the back casing.
    • Do not tug on the speakers because they are connected to fragile wires.
  5. Zeki Droid Tablet Camera Replacement: stap 5, afbeelding 1 van 1
    • Pull the speakers away from the back casing carefullly.
  6. Zeki Droid Tablet Camera Replacement, Camera: stap 6, afbeelding 1 van 2 Zeki Droid Tablet Camera Replacement, Camera: stap 6, afbeelding 2 van 2
    • Grip the camera on both sides using tweezers or your fingers, and carefully lift it off the board.
    • The adhesive may make it difficult to remove the cameras from the tablet.
  7. Zeki Droid Tablet Camera Replacement: stap 7, afbeelding 1 van 1
    • Undo the ZIF connector that is connecting the cameras to the motherboard using a plastic spudger or fingernail.
    • This guide has more information on how to undo the ZIF connector
    • Do not yank the ZIF connector. It should come apart very easily with little force needed.
  8. Zeki Droid Tablet Camera Replacement: stap 8, afbeelding 1 van 1
    • Pull the copper connection carefully away from the motherboard of the tablet to completely remove the camera.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Colleen McFadden
268 Reputatie
2 handleidingen geschreven
Colorado Springs, Team 2-6, Panko Spring 2015 Lid van Colorado Springs, Team 2-6, Panko Spring 2015
UCCS-PANKO-S15S2G6
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 375
