Inleiding
Replacing the cameras that may be cracked or faulty on your Zeki Droid Tablet. This procedure should take no more then twenty minutes to complete. The process will include using tools such as spudgers, and tweezers.
Wat je nodig hebt
Remove the back casing by slowly popping each tab out with a plastic opening tool.
Gereedschap gebruikt in deze stap:Tweezers$4.99
Grip the camera on both sides using tweezers or your fingers, and carefully lift it off the board.
Één andere persoon heeft deze handleiding voltooid.
