Ga door naar hoofdinhoud
Zeepad 7.0 Screen Replacement
Wat je nodig hebt
  1. Zeepad 7.0 Screen Replacement, Screen: stap 1, afbeelding 1 van 2 Zeepad 7.0 Screen Replacement, Screen: stap 1, afbeelding 2 van 2
    • Power off the device and keep it unplugged.
    • Open the case using a plastic opening tool around the edges. Slightly pull the cover off.
    • Do not completely remove back casing because there is a speaker attached to the back.
  2. Zeepad 7.0 Screen Replacement: stap 2, afbeelding 1 van 1
    • Using the Phillips Head 0 bit, carefully unscrew the three 3.5mm screws holding the motherboard in place on to the back of the screen.
  3. Zeepad 7.0 Screen Replacement: stap 3, afbeelding 1 van 2 Zeepad 7.0 Screen Replacement: stap 3, afbeelding 2 van 2
    • Disconnect the two ribbon cables between the screen and the motherboard.
    • Be careful not to rip out the ribbon cables or you can harm the ports.
  4. Zeepad 7.0 Screen Replacement: stap 4, afbeelding 1 van 1
    • Cut the power cables connecting between the screen and the motherboard. There should be a red and black cable each.
  5. Zeepad 7.0 Screen Replacement: stap 5, afbeelding 1 van 2 Zeepad 7.0 Screen Replacement: stap 5, afbeelding 2 van 2
    • Separate the front screen protector from the lcd screen. There are clamps holding the screen in place.
  6. Zeepad 7.0 Screen Replacement: stap 6, afbeelding 1 van 3 Zeepad 7.0 Screen Replacement: stap 6, afbeelding 2 van 3 Zeepad 7.0 Screen Replacement: stap 6, afbeelding 3 van 3
    • Separate the LCD screen from the metal protecting case with the metal spudger.
  7. Zeepad 7.0 Screen Replacement: stap 7, afbeelding 1 van 3 Zeepad 7.0 Screen Replacement: stap 7, afbeelding 2 van 3 Zeepad 7.0 Screen Replacement: stap 7, afbeelding 3 van 3
    • After creating space to work, warm up a soldering iron.
    • Apply heat onto the solder over the corresponding cut wires to the new screen wires.
    • Hoe moet je (de-)solderen?
    • The soldering iron will be extremely hot. Keep out of direct contact to other wires, the motherboard, and especially the battery.
    • Keep out of reach of children.
Conclusie
To reassemble your device, follow these instructions in order.
Één andere persoon heeft deze handleiding voltooid.
Harry Winter
157 Reputatie
1 Handleiding geschreven
IUPUI, Team S2-G1, Harley Spring 2018 Lid van IUPUI, Team S2-G1, Harley Spring 2018
IUPUI-HARLEY-S18S2G1
3 Leden
4 handleidingen geschreven
2 opmerkingen
where do you buy the screen?
Zuzzi Z Amend - Antwoord
i need a battery an a screen? is their a place on this page where to get them?
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 7
Altijd: 468
