Ga door naar hoofdinhoud
ZTE Prestige 2 Front-Facing Camera Replacement
Wat je nodig hebt
  1. ZTE Prestige 2 Front-Facing Camera Replacement, Battery: stap 1, afbeelding 1 van 3 ZTE Prestige 2 Front-Facing Camera Replacement, Battery: stap 1, afbeelding 2 van 3 ZTE Prestige 2 Front-Facing Camera Replacement, Battery: stap 1, afbeelding 3 van 3
    • Use the iFixit opening tool to open up the device by wedging the tool under the back case and popping it open.
  2. ZTE Prestige 2 Front-Facing Camera Replacement: stap 2, afbeelding 1 van 2 ZTE Prestige 2 Front-Facing Camera Replacement: stap 2, afbeelding 2 van 2
    • Remove the battery.
  3. ZTE Prestige 2 Front-Facing Camera Replacement, Back Panel: stap 3, afbeelding 1 van 3 ZTE Prestige 2 Front-Facing Camera Replacement, Back Panel: stap 3, afbeelding 2 van 3 ZTE Prestige 2 Front-Facing Camera Replacement, Back Panel: stap 3, afbeelding 3 van 3
    • Use a Phillips #00 screwdriver to unscrew all 12 of the 3 mm Phillips screws located along the edges of the device’s back panel, as well as the blue 3mm Phillips screw labeled “ZTE” located towards the top right.
  4. ZTE Prestige 2 Front-Facing Camera Replacement: stap 4, afbeelding 1 van 3 ZTE Prestige 2 Front-Facing Camera Replacement: stap 4, afbeelding 2 van 3 ZTE Prestige 2 Front-Facing Camera Replacement: stap 4, afbeelding 3 van 3
    • Then use the iFixit opening tool and wedge it under the grey back panel and pop it off.
    • There will be a lot of resistance, apply adequate pressure.
  5. ZTE Prestige 2 Front-Facing Camera Replacement, Front-Facing Camera: stap 5, afbeelding 1 van 2 ZTE Prestige 2 Front-Facing Camera Replacement, Front-Facing Camera: stap 5, afbeelding 2 van 2
    • Use the curved tweezers to lift up the press fit camera connector.
    • The front facing camera is located directly to the left of the rear facing camera.
    • Lift out the front facing camera.
Conclusie
Maria Stock
524 Reputatie
5 handleidingen geschreven
UW Stout, Team S1-G4, Schneider-Bateman Spring 2020 Lid van UW Stout, Team S1-G4, Schneider-Bateman Spring 2020
UWSTOUT-SCHNEIDER-BATEMAN-S20S1G4
3 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 78
