Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
This guide will help you replace the battery of your ZTE Prestige 2. Before you start, check out our troubleshooting page that will help you decipher any basic problems before taking your device apart. Some reasons you may need to conduct this replacement is because the battery may be burnt out, or have water damage. Before beginning, make sure to power off your device completely and disconnect from any external power source.
Onderdelen
Geen onderdelen opgegeven.
  1. Use the iFixit opening tool to open up the device by wedging the tool under the back case and popping it open. Use the iFixit opening tool to open up the device by wedging the tool under the back case and popping it open. Use the iFixit opening tool to open up the device by wedging the tool under the back case and popping it open.
    • Use the iFixit opening tool to open up the device by wedging the tool under the back case and popping it open.
  2. Remove the battery. Remove the battery.
    • Remove the battery.
Conclusie
Maria Stock
524 Reputatie
5 handleidingen geschreven
UW Stout, Team S1-G4, Schneider-Bateman Spring 2020 Lid van UW Stout, Team S1-G4, Schneider-Bateman Spring 2020
UWSTOUT-SCHNEIDER-BATEMAN-S20S1G4
3 Leden
7 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 51
