Ga door naar hoofdinhoud
ZTE Max XL SIM Card Replacement
Wat je nodig hebt
  1. ZTE Max XL SIM Card Replacement, Battery: stap 1, afbeelding 1 van 2 ZTE Max XL SIM Card Replacement, Battery: stap 1, afbeelding 2 van 2
    • Before any disassembly, make sure the phone is powered off.
    • Use the SIM Card Eject Tool to remove the SIM card tray. To do this, insert the key into the hole on the side of the phone near the SIM card tray.
  2. ZTE Max XL SIM Card Replacement: stap 2, afbeelding 1 van 2 ZTE Max XL SIM Card Replacement: stap 2, afbeelding 2 van 2
    • Apply the iOpener to the back of the phone. For instructions on how to use the iOpener, use this guide.
    • On the phone shown there was adhesive on the top and bottom of the phone backing, so we specifically heated these areas.
    • Do not heat the phone too much in one area - it may warp the plastic backing.
  3. ZTE Max XL SIM Card Replacement: stap 3, afbeelding 1 van 3 ZTE Max XL SIM Card Replacement: stap 3, afbeelding 2 van 3 ZTE Max XL SIM Card Replacement: stap 3, afbeelding 3 van 3
    • Starting at one corner, wedge the plastic opening pick underneath the plastic backing to start undoing the tabs that connect the backing to the phone. There are 3 tabs on top and bottom, and 6 on each side.
    • Use extreme caution to not puncture the lithium ion battery.
  4. ZTE Max XL SIM Card Replacement: stap 4, afbeelding 1 van 2 ZTE Max XL SIM Card Replacement: stap 4, afbeelding 2 van 2
    • Carefully undo the ribbon wire for the fingerprint scanner before full removal of the backing.
    • There are two 3.4mm JIS 00 screws that hold the wire in place, one may be under a lock sticker. Remove the screws with the JIS 00 screwdriver.
  5. ZTE Max XL SIM Card Replacement: stap 5, afbeelding 1 van 2 ZTE Max XL SIM Card Replacement: stap 5, afbeelding 2 van 2
    • After removal of the two 3.4mm JIS 00 screws, disconnect the connector that attaches the ribbon wire from the main part of the phone.
  6. ZTE Max XL SIM Card Replacement: stap 6, afbeelding 1 van 3 ZTE Max XL SIM Card Replacement: stap 6, afbeelding 2 van 3 ZTE Max XL SIM Card Replacement: stap 6, afbeelding 3 van 3
    • Remove the nineteen 3.4mm JIS 00 screws on the perimeter of the back using the JIS 00 screwdriver.
  7. ZTE Max XL SIM Card Replacement: stap 7, afbeelding 1 van 3 ZTE Max XL SIM Card Replacement: stap 7, afbeelding 2 van 3 ZTE Max XL SIM Card Replacement: stap 7, afbeelding 3 van 3
    • Use a plastic opening pick between the screen and side trim battery cover to remove the screen.
    • If the SIM Card is still in place during removal of the siding, take care during removal to avoid damaging the SIM Card.
  8. ZTE Max XL SIM Card Replacement: stap 8, afbeelding 1 van 1
    • On the top left of the battery, flip the metal clips with a pick and remove the battery ribbon from the shell.
  9. ZTE Max XL SIM Card Replacement: stap 9, afbeelding 1 van 1
    • Using the iOpener heating pack, CAREFULLY apply heat to the battery. For instructions of how to use the iOpener, use this guide
    • Use extreme caution to not overheat the battery. Never use any open flames or high heat.
    • Adhesive is used to secure the battery to the phone. If you're having problems you may need to heat the screen as well.
  10. ZTE Max XL SIM Card Replacement: stap 10, afbeelding 1 van 3 ZTE Max XL SIM Card Replacement: stap 10, afbeelding 2 van 3 ZTE Max XL SIM Card Replacement: stap 10, afbeelding 3 van 3
    • Using the iFixit opening tools carefully pry the edges of the battery away from the casing.
    • While prying, take care to not scrape the wires underneath the battery.
  11. ZTE Max XL SIM Card Replacement: stap 11, afbeelding 1 van 1
    • With the battery removed, you can now insert the new battery or replace other parts within your phone.
  12. ZTE Max XL SIM Card Replacement, SIM Card: stap 12, afbeelding 1 van 3 ZTE Max XL SIM Card Replacement, SIM Card: stap 12, afbeelding 2 van 3 ZTE Max XL SIM Card Replacement, SIM Card: stap 12, afbeelding 3 van 3
    • Disconnect the six connections located on the large circuit board.
    • The camera itself is lightweight so take care during disconnection of the connector not to lose it.
  13. ZTE Max XL SIM Card Replacement: stap 13, afbeelding 1 van 2 ZTE Max XL SIM Card Replacement: stap 13, afbeelding 2 van 2
    • Gently pry off the large circuit board using the plastic spudger.
  14. ZTE Max XL SIM Card Replacement: stap 14, afbeelding 1 van 1
    • With the circuit board removed, press the small button next to the SIM Card slot, this will cause the tray to pop out slightly. Remove the SIM card tray.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Olivia Wolf
1.400 Reputatie
5 handleidingen geschreven
UW Stout, Team S8-G2, Ogden Spring 2018 Lid van UW Stout, Team S8-G2, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G2
4 Leden
10 handleidingen geschreven
2 opmerkingen
My husband cell phone is a zte android and the plug in part was complelty not workimg so he took the back off and all that changed the usb plug in charger part and put his cell back together and it charges and it works besides when je gets on line like google it lets him on for just a swcond and then jt will say lost connection check your netwprk and we have unlimited high speed data is there something he might of accidently done wrong when he replaced the charging part please help
sissybyford - Antwoord
why is it so difficult to change a SIM CARD?!!
[deleted] - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 11
Altijd: 2,618
