Ga door naar hoofdinhoud
ZTE Maven 3 Back Camera Replacement
Wat je nodig hebt
    1. ZTE Maven 3 Back Camera Replacement, Back Cover: stap 1, afbeelding 1 van 3 ZTE Maven 3 Back Camera Replacement, Back Cover: stap 1, afbeelding 2 van 3 ZTE Maven 3 Back Camera Replacement, Back Cover: stap 1, afbeelding 3 van 3
      • Locate the small indent on the back right bottom corner of the phone.
      • Put the pry tool or your fingertip inside the small gap on the bottom right of the back of the phone and pop up the cover.
      • Continue to go around the phone until the cover is completely off the back of the pull and put it aside.
      Vraag FixBot
      Voeg opmerking toe
    1. ZTE Maven 3 Back Camera Replacement, Battery: stap 2, afbeelding 1 van 3 ZTE Maven 3 Back Camera Replacement, Battery: stap 2, afbeelding 2 van 3 ZTE Maven 3 Back Camera Replacement, Battery: stap 2, afbeelding 3 van 3
      • Locate the battery in the middle of the back of the phone.
      • Push in and up on the battery to remove it from its slot.
      • Put the battery aside.
      Vraag FixBot
      Voeg opmerking toe
    1. ZTE Maven 3 Back Camera Replacement, Midframe: stap 3, afbeelding 1 van 1
      • Use a Phillips #00 screwdriver to remove twelve 2 mm screws along the back outer edges of the phone.
      Vraag FixBot
      Voeg opmerking toe
    2. ZTE Maven 3 Back Camera Replacement: stap 4, afbeelding 1 van 1
      • There’s a 13th 2 mm screw with a lock sticker over it on the bottom right corner. Insert the #00 Phillips screwdriver in the middle, breaking the sticker, and take the screw out.
      Vraag FixBot
      Voeg opmerking toe
    3. ZTE Maven 3 Back Camera Replacement: stap 5, afbeelding 1 van 2 ZTE Maven 3 Back Camera Replacement: stap 5, afbeelding 2 van 2
      • Slide the pry tool into the middle of the connection between the screen and the back of the phone.
      • Once in, slide the pry tool around the phone, separating the screen and the back of the phone.
      • The detached piece is the midframe, and you can place it aside when detached.
      Vraag FixBot
      Voeg opmerking toe
    1. ZTE Maven 3 Back Camera Replacement, Back Camera: stap 6, afbeelding 1 van 2 ZTE Maven 3 Back Camera Replacement, Back Camera: stap 6, afbeelding 2 van 2
      Gereedschap gebruikt in deze stap:
      • Detach the ribbon cable connecting the camera in the top middle of the phone.
      • Use blunt tweezers to pull the camera off and put it aside.
      • Using this same method, grab the tweezers and insert the replacement camera.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jasmine Turner
91 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team 3-1, Konn Fall 2023 Lid van UMass Dartmouth, Team 3-1, Konn Fall 2023
UMASSD-KONN-F23S3G1
3 Leden
30 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 27
Altijd: 310
