Ga door naar hoofdinhoud
ZTE Grand X Max Plus Back Cover Replacement
Wat je nodig hebt
    1. ZTE Grand X Max Plus Back Cover Replacement, Back Cover: stap 1, afbeelding 1 van 1
      • Make sure you turn off your phone before starting.
      • Heat the phone using a heating pad, heat gun, or hair dryer to loosen the glue. You just need to heat the back of the phone.
      • You can also use a hair dryer or a heating gun for this step.
      Vraag FixBot
      Voeg opmerking toe
    2. ZTE Grand X Max Plus Back Cover Replacement: stap 2, afbeelding 1 van 2 ZTE Grand X Max Plus Back Cover Replacement: stap 2, afbeelding 2 van 2
      • After the phone is heated, use the blue plastic opening tool on both sides of the phone.
      • Don't apply too much pressure because the cover can crack easily.
      • To avoid that your cover cracks, you can add tape to back cover.
      • You can use a suction cup to help remove the battery.
      Vraag FixBot
      Voeg opmerking toe
    3. ZTE Grand X Max Plus Back Cover Replacement: stap 3, afbeelding 1 van 2 ZTE Grand X Max Plus Back Cover Replacement: stap 3, afbeelding 2 van 2
      • Carefully remove the cover from the phone.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Jordano Baer
716 Reputatie
5 handleidingen geschreven
USF Tampa, Team S9-G4, Remmell Fall 2017 Lid van USF Tampa, Team S9-G4, Remmell Fall 2017
USFT-REMMELL-F17S9G4
4 Leden
25 handleidingen geschreven
1Gids Commentaar
There seems to be an antenna attached to the mid frame that gets stuck to the back glass on the top left. Does anyone know what this is??
Kiki Jade - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 26
Altijd: 758
