Ga door naar hoofdinhoud
ZTE Compel Battery Replacement
Wat je nodig hebt
  1. ZTE Compel Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Place the phone on a flat surface with the screen facing down. This will allow easy access to the removable black plastic cover on the back of the phone.
    Vraag FixBot
    Voeg opmerking toe
  2. ZTE Compel Battery Replacement: stap 2, afbeelding 1 van 1
    • In the bottom right corner of the device, use your fingernail to remove the back cover of the phone by lifting up and holding the device with your other hand.
    Vraag FixBot
    Voeg opmerking toe
  3. ZTE Compel Battery Replacement: stap 3, afbeelding 1 van 1
    • In the top-right area of the battery, use your fingernail to lift the battery out of the phone.
    • If your battery is corroded, take all necessary precautions, such as, gloves and protective eyewear.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Kidron Stamper
327 Reputatie
3 handleidingen geschreven
Ohio State, Team S1-G4, Whitney Fall 2018 Lid van Ohio State, Team S1-G4, Whitney Fall 2018
OSU-WHITNEY-F18S1G4
2 Leden
20 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 35
Altijd: 483
