Ga door naar hoofdinhoud
ZTE Boost MAX N9520 Battery Replacement
Wat je nodig hebt
  1. ZTE Boost MAX N9520 Battery Replacement, Battery: stap 1, afbeelding 1 van 2 ZTE Boost MAX N9520 Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • First, remove the microSD tray, use a sim ejector tool for this.
    • Begin by removing the upper and lower plastic panels. Pry the top with a spudger from the corners as shown in the red circle.
    • Remove the SIM card.
    • Next pry off the lower plastic panel. This one is stuck on a little bit more.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Sebastian Edinger
517 Reputatie
1 Handleiding geschreven
Één opmerking
An additional more comprehensive wiki troubleshooting guide for the ZTE Max …compiled by a team of students here on “IFIXIT” that I recently discovered that you may also find helpful.
ZTE Max XL Troubleshooting
Jason Thompson - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 11
Altijd: 3,081
