Inleiding
If your ZTE Blade X Max LCD is damaged—has dark spots, cracks, unresponsive to touch—and you have already finished troubleshooting, then you may need to replace it.
This guide requires removing the back of the phone. You will have to use heating products to complete this guide. If you are using the iFixit iOpener, or a heating pad, be sure to follow the instructions for that particular product.
To remove the battery, you will have to heat it. Be sure not to overheat the battery. If you do, the battery will swell and be rendered useless.
Wat je nodig hebt
Use the iOpener or heating pad to heat around the edges of the phone to melt the adhesive.
Remove the SD and SIM cards by pulling out the card tray from the slot on the right side of the device.
Gereedschap gebruikt in deze stap:Tweezers$4.99
Once the motherboard is exposed, locate the front camera connection in the top right corner of the motherboard.
Use the tweezers to remove the front camera.
Use the iOpener or heating pad to heat the phone. This will loosen the adhesive below the battery.
Remove the single 1mm Phillips #000 screw from the motherboard.
Detach the five flat connectors.
The LCD cable will be completely exposed once the motherboard is removed.
Use the tweezers to remove the protective sticker and the entire component.
Één andere persoon heeft deze handleiding voltooid.
