Ga door naar hoofdinhoud
ZCWA BR151 Wheel Replacement
Wat je nodig hebt
    1. ZCWA BR151 Wheel Replacement, Water Tank: stap 1, afbeelding 1 van 1
      • Turn off the device.
      Vraag FixBot
      Voeg opmerking toe
    2. ZCWA BR151 Wheel Replacement: stap 2, afbeelding 1 van 2 ZCWA BR151 Wheel Replacement: stap 2, afbeelding 2 van 2
      • Remove the water tank by sliding the latch down with a finger and grasping the bottom of the water tank.
      • Pull it out.
      Vraag FixBot
      Voeg opmerking toe
    1. ZCWA BR151 Wheel Replacement, Wheel: stap 3, afbeelding 1 van 2 ZCWA BR151 Wheel Replacement, Wheel: stap 3, afbeelding 2 van 2
      • Flip the device over to access the bottom panel.
      • Remove the cloth mop covering by lifting it from the velcro on the plastic mop attachment.
      • Remove the plastic mop attachment by placing your fingers underneath and prying it up.
      Vraag FixBot
      Voeg opmerking toe
    2. ZCWA BR151 Wheel Replacement: stap 4, afbeelding 1 van 1
      • Remove the six 6 mm screws on the bumper guards using a Phillips #0 screwdriver.
      • Remove the bumper guards by lifting them.
      Vraag FixBot
      Voeg opmerking toe
    3. ZCWA BR151 Wheel Replacement: stap 5, afbeelding 1 van 1
      • Use a Phillips #1 screwdriver to remove the ten 10 mm screws from the bottom plate.
      Vraag FixBot
      Voeg opmerking toe
    4. ZCWA BR151 Wheel Replacement: stap 6, afbeelding 1 van 1
      • Use a Phillips #1 screwdriver to remove three 8 mm screws from the wheel plate.
      Vraag FixBot
      Voeg opmerking toe
    5. ZCWA BR151 Wheel Replacement: stap 7, afbeelding 1 van 2 ZCWA BR151 Wheel Replacement: stap 7, afbeelding 2 van 2
      • Carefully lift the bottom panel off of the top.
      • The top and bottom panels are attached by a set of wires. They will not fully detach at this point.
      • Gently place the bottom of the device on your workspace surface, wheels down, exposing the inner workings of the device.
      Vraag FixBot
      Voeg opmerking toe
    6. ZCWA BR151 Wheel Replacement: stap 8, afbeelding 1 van 1
      • Though optional, we recommend separating the top and bottom panels for easy access to the wheels.
      • Pinch the wire bracket that is on the top panel while pulling the bracket away.
      • Pull the cable away from the connector in the same direction as the individual wires are running.
      • Pull evenly on the full width of the cable so that no individual wires are overly strained.
      Vraag FixBot
      Voeg opmerking toe
    7. ZCWA BR151 Wheel Replacement: stap 9, afbeelding 1 van 3 ZCWA BR151 Wheel Replacement: stap 9, afbeelding 2 van 3 ZCWA BR151 Wheel Replacement: stap 9, afbeelding 3 van 3
      • Using a Phillips #1 screwdriver, remove the single screw to the spring.
      • Once the spring is unscrewed, slowly pull it towards you, then to the left of the spring bracket to free the spring.
      Vraag FixBot
      Voeg opmerking toe
    8. ZCWA BR151 Wheel Replacement: stap 10, afbeelding 1 van 2 ZCWA BR151 Wheel Replacement: stap 10, afbeelding 2 van 2
      • The wheel's motor is still attached to the motherboard of the device. Locate the wheel's wiring and the port connector on the motherboard.
      • Pinch the silver brackets and pull the wire casing away from the motherboard.
      • Remove the wheel from the vacuum.
      • Repeat Steps 6-10 to replace the wheel on the opposite side.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 55
Altijd: 1,116
