Ga door naar hoofdinhoud
ZCWA BR151 Sprayer/Pump Replacement
Wat je nodig hebt
    1. ZCWA BR151 Sprayer/Pump Replacement, Water Tank: stap 1, afbeelding 1 van 1
      • Turn off the device.
      Vraag FixBot
      Voeg opmerking toe
    2. ZCWA BR151 Sprayer/Pump Replacement: stap 2, afbeelding 1 van 2 ZCWA BR151 Sprayer/Pump Replacement: stap 2, afbeelding 2 van 2
      • Remove the water tank by sliding the latch down with a finger and grasping the bottom of the water tank.
      • Pull it out.
      Vraag FixBot
      Voeg opmerking toe
    1. ZCWA BR151 Sprayer/Pump Replacement, Sprayer/Pump: stap 3, afbeelding 1 van 2 ZCWA BR151 Sprayer/Pump Replacement, Sprayer/Pump: stap 3, afbeelding 2 van 2
      • Flip the device over to access the bottom panel.
      • Remove the cloth mop covering by lifting it from the velcro on the plastic mop attachment.
      • Remove the plastic mop attachment by placing your fingers underneath and prying it up.
      Vraag FixBot
      Voeg opmerking toe
    2. ZCWA BR151 Sprayer/Pump Replacement: stap 4, afbeelding 1 van 1
      • Remove the six 6 mm screws on the bumper guards using a Phillips #0 screwdriver.
      • Remove the bumper guards by lifting them.
      Vraag FixBot
      Voeg opmerking toe
    3. ZCWA BR151 Sprayer/Pump Replacement: stap 5, afbeelding 1 van 1
      • Use a Phillips #1 screwdriver to remove the ten 10 mm screws from the bottom plate.
      Vraag FixBot
      Voeg opmerking toe
    4. ZCWA BR151 Sprayer/Pump Replacement: stap 6, afbeelding 1 van 2 ZCWA BR151 Sprayer/Pump Replacement: stap 6, afbeelding 2 van 2
      • Carefully lift the bottom panel off of the top.
      • The top and bottom panels are attached by a set of wires. They will not fully detach at this point.
      • Gently place the bottom of the device on your workspace surface, wheels down, exposing the inner workings of the device.
      Vraag FixBot
      Voeg opmerking toe
    5. ZCWA BR151 Sprayer/Pump Replacement: stap 7, afbeelding 1 van 1
      • Though optional, we recommend separating the top and bottom panels for easy access to the sprayer/pump.
      • Pinch the wire bracket that is on the top panel while pulling the bracket away.
      • Pull the cable away from the connector in the same direction as the individual wires are running.
      • Pull evenly on the full width of the cable so that no individual wires are overly strained.
      Vraag FixBot
      Voeg opmerking toe
    6. ZCWA BR151 Sprayer/Pump Replacement: stap 8, afbeelding 1 van 3 ZCWA BR151 Sprayer/Pump Replacement: stap 8, afbeelding 2 van 3 ZCWA BR151 Sprayer/Pump Replacement: stap 8, afbeelding 3 van 3
      • The sprayer is slotted in place with grooves. Slide up the sprayer by lifting it up with your fingers.
      • The sprayer/pump should loosely be free, except for wires connecting it to the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    7. ZCWA BR151 Sprayer/Pump Replacement: stap 9, afbeelding 1 van 3 ZCWA BR151 Sprayer/Pump Replacement: stap 9, afbeelding 2 van 3 ZCWA BR151 Sprayer/Pump Replacement: stap 9, afbeelding 3 van 3
      • Turn the device around so that the motherboard is closest to you.
      • Track the red and black wire cables from the sprayer/pump to the motherboard.
      • Remove the sprayer/pump wiring from the port on the motherboard by pinching the silver brackets and pull the wire casing away from the motherboard.
      • Remove the sprayer/pump from the vacuum.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 32
Altijd: 1,119
