Ga door naar hoofdinhoud
ZCWA BR151 Battery Replacement
Wat je nodig hebt
    1. ZCWA BR151 Battery Replacement, Water Tank: stap 1, afbeelding 1 van 1
      • Turn off the device.
      Vraag FixBot
      Voeg opmerking toe
    2. ZCWA BR151 Battery Replacement: stap 2, afbeelding 1 van 2 ZCWA BR151 Battery Replacement: stap 2, afbeelding 2 van 2
      • Remove the water tank by sliding the latch down with a finger and grasping the bottom of the water tank.
      • Pull it out.
      Vraag FixBot
      Voeg opmerking toe
    1. ZCWA BR151 Battery Replacement, Battery: stap 3, afbeelding 1 van 2 ZCWA BR151 Battery Replacement, Battery: stap 3, afbeelding 2 van 2
      • Flip the device over to access the panels on the back.
      • Rotate the device to where the battery panel is closest to you.
      • Using a Phillips #1 screwdriver, remove the two 10 mm screws from the battery panel.
      Vraag FixBot
      Voeg opmerking toe
    2. ZCWA BR151 Battery Replacement: stap 4, afbeelding 1 van 2 ZCWA BR151 Battery Replacement: stap 4, afbeelding 2 van 2
      • From the opposite end of the battery wires, use an opening tool to pry the battery out.
      • Do not use metal objects to pry out the battery.
      • You may need to rotate the device depending on your hand prominence.
      Vraag FixBot
      Voeg opmerking toe
    3. ZCWA BR151 Battery Replacement: stap 5, afbeelding 1 van 1
      • Peel off the electrical tape that wraps around the battery's wire connectors.
      Vraag FixBot
      Voeg opmerking toe
    4. ZCWA BR151 Battery Replacement: stap 6, afbeelding 1 van 2 ZCWA BR151 Battery Replacement: stap 6, afbeelding 2 van 2
      • Pinch the two lock mechanisms on the wire connectors while pulling them apart.
      • Set aside the old battery to dispose of later.
      • Batteries can be safely disposed of at your local recycling center with the help of a professional.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Kaitlyn Baltz
431 Reputatie
3 handleidingen geschreven
3Gids Commentaar
Ok cool I hope it works
Blueobear - Antwoord Deel
Where to buy the replacement battery and what is the part number
Andre Bellanger - Antwoord Deel
Myra Mitchell - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 34
Altijd: 1,487
