Ga door naar hoofdinhoud
Yuneec Typhoon H Plus Propeller Replacement
    1. Yuneec Typhoon H Plus Propeller Replacement, Propeller: stap 1, afbeelding 1 van 1
      • Locate the broken propeller and figure out if it is a A-propeller or B-propeller.
      • An A-propeller will have a black button in the center and an A imprinted on the propeller.
      • A B-propeller will have a white button and a B imprinted on the propeller.
      • Though the A and B propellers are different the steps to replace one are the same.
      Vraag FixBot
      Voeg opmerking toe
    2. Yuneec Typhoon H Plus Propeller Replacement: stap 2, afbeelding 1 van 1
      • Press down on the button firmly.
      Vraag FixBot
      Voeg opmerking toe
    3. Yuneec Typhoon H Plus Propeller Replacement: stap 3, afbeelding 1 van 2 Yuneec Typhoon H Plus Propeller Replacement: stap 3, afbeelding 2 van 2
      • Hold the base of the propeller with your pointer finger.
      • Make sure to continue to hold the button down. Rotate the propeller counter-clockwise, holding the base steady.
      • Lift the propeller off the drone.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Brice Black
557 Reputatie
4 handleidingen geschreven
Cal Poly, Team S2-G1, White Winter 2020 Lid van Cal Poly, Team S2-G1, White Winter 2020
CPSU-WHITE-W20S2G1
4 Leden
5 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 22
Altijd: 442
