Ga door naar hoofdinhoud
Yuneec Typhoon H Plus Arm Replacement
Wat je nodig hebt
    1. Yuneec Typhoon H Plus Arm Replacement, Motor: stap 1, afbeelding 1 van 2 Yuneec Typhoon H Plus Arm Replacement, Motor: stap 1, afbeelding 2 van 2
      • Flip the drone over so the bottom is facing upwards.
      • Remove ten 9.5mm Hex 2 screws attached to the bottom shell.
      Vraag FixBot
      Voeg opmerking toe
    2. Yuneec Typhoon H Plus Arm Replacement: stap 2, afbeelding 1 van 3 Yuneec Typhoon H Plus Arm Replacement: stap 2, afbeelding 2 van 3 Yuneec Typhoon H Plus Arm Replacement: stap 2, afbeelding 3 van 3
      • Carefully detach the top billit piece from the drone. There are internal clips that need to be detached from the top piece in order for the entire unit to come off.
      • Once the lid is off, detach the wire that holds the lid to the body. Press down on the clip and slide the wire out.
      Vraag FixBot
      Voeg opmerking toe
    3. Yuneec Typhoon H Plus Arm Replacement: stap 3, afbeelding 1 van 3 Yuneec Typhoon H Plus Arm Replacement: stap 3, afbeelding 2 van 3 Yuneec Typhoon H Plus Arm Replacement: stap 3, afbeelding 3 van 3
      • Find the base of the arm you are replacing and remove the electrical tape.
      • Disconnect the red, black, and blue wires. Also disconnect the white clip that is associated with those same wires.
      • You may need a pair of pliers to get enough grip to disconnect the three wires.
      Vraag FixBot
      Voeg opmerking toe
    4. Yuneec Typhoon H Plus Arm Replacement: stap 4, afbeelding 1 van 3 Yuneec Typhoon H Plus Arm Replacement: stap 4, afbeelding 2 van 3 Yuneec Typhoon H Plus Arm Replacement: stap 4, afbeelding 3 van 3
      • Find the pin that holds the arm by pulling down the bottom shell. Use a Hex bit 2 screwdriver to remove it
      • After removing the pin, pull the arm and wires out of the drone.
      Vraag FixBot
      Voeg opmerking toe
    5. Yuneec Typhoon H Plus Arm Replacement: stap 5, afbeelding 1 van 2 Yuneec Typhoon H Plus Arm Replacement: stap 5, afbeelding 2 van 2
      • Use the wrench tool from the Yuneec drone box to remove the bottom cap from the motor mount. Twist clockwise until it pops; then it will slide out easily.
      Vraag FixBot
      Voeg opmerking toe
    6. Yuneec Typhoon H Plus Arm Replacement: stap 6, afbeelding 1 van 2 Yuneec Typhoon H Plus Arm Replacement: stap 6, afbeelding 2 van 2
      • Disconnect the electrical board from the wire and thread the clip through the arm to the side with the motor to remove the entire motor/wire assembly.
      • After both sides of the wire are on the side with the motor, pull the wires through the length of the arm.
      Vraag FixBot
      Voeg opmerking toe
    1. Yuneec Typhoon H Plus Arm Replacement, Arm: stap 7, afbeelding 1 van 3 Yuneec Typhoon H Plus Arm Replacement, Arm: stap 7, afbeelding 2 van 3 Yuneec Typhoon H Plus Arm Replacement, Arm: stap 7, afbeelding 3 van 3
      • Remove the small Phillips #000 screw that holds the arm clip in place.
      • Use iFixit's metal spudger to pry up on the clip to release it from the arm and pull it out with your fingers.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Theron Dale
109 Reputatie
1 Handleiding geschreven
Cal Poly, Team S2-G1, White Winter 2020 Lid van Cal Poly, Team S2-G1, White Winter 2020
CPSU-WHITE-W20S2G1
4 Leden
5 handleidingen geschreven
1Gids Commentaar
Would this be the same process for the Yuneec H520?
Reon Sharp - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 37
Altijd: 1,224
