Ga door naar hoofdinhoud
Yuneec Breeze 4K Camera Replacement
Wat je nodig hebt
    1. Yuneec Breeze 4K Camera Replacement, Camera: stap 1, afbeelding 1 van 2 Yuneec Breeze 4K Camera Replacement, Camera: stap 1, afbeelding 2 van 2
      • Before you begin start by putting on a ESD wrist strap to prevent ESD damage and remove the battery.
      • Once the battery is taken out, flip over the drone so that the cameras are now facing up.
      Vraag FixBot
      Voeg opmerking toe
    2. Yuneec Breeze 4K Camera Replacement: stap 2, afbeelding 1 van 1
      • Using small pliers grip the connector of the wire and pull it out slowly.
      Vraag FixBot
      Voeg opmerking toe
    3. Yuneec Breeze 4K Camera Replacement: stap 3, afbeelding 1 van 1
      • Remove the four white rubber dampeners located in each corner of the frame that hold the it in place.
      Vraag FixBot
      Voeg opmerking toe
    4. Yuneec Breeze 4K Camera Replacement: stap 4, afbeelding 1 van 1
      • Unplug the two vertical plugs located in the rear of the M7 board.
      Vraag FixBot
      Voeg opmerking toe
    5. Yuneec Breeze 4K Camera Replacement: stap 5, afbeelding 1 van 1
      • Slightly lift the M7 board to remove the two plugs located under the rear of the board.
      Vraag FixBot
      Voeg opmerking toe
    6. Yuneec Breeze 4K Camera Replacement: stap 6, afbeelding 1 van 1
      • Once all plugs on top of the M7 board are disconnected, carefully lift the M7 board onto its side and remove all plugs on the bottom.
      Vraag FixBot
      Voeg opmerking toe
    7. Yuneec Breeze 4K Camera Replacement: stap 7, afbeelding 1 van 2 Yuneec Breeze 4K Camera Replacement: stap 7, afbeelding 2 van 2
      • Tilt the M7 board onto its side. Using the Phillips #00 screwdriver remove the two black screws connected to the large black two pronged input.
      Vraag FixBot
      Voeg opmerking toe
    8. Yuneec Breeze 4K Camera Replacement: stap 8, afbeelding 1 van 1
      • Using a pair of pliers pull apart the battery connector.
      Vraag FixBot
      Voeg opmerking toe
    9. Yuneec Breeze 4K Camera Replacement: stap 9, afbeelding 1 van 1
      • Flip over the entire frame along with the M7 board and the A9 board.
      Vraag FixBot
      Voeg opmerking toe
    10. Yuneec Breeze 4K Camera Replacement: stap 10, afbeelding 1 van 1
      • There will be 4 screws that hold the A9 board together. Using a H1.5 Alan bit unscrew those bolts to take the A9 board apart.
      Vraag FixBot
      Voeg opmerking toe
    11. Yuneec Breeze 4K Camera Replacement: stap 11, afbeelding 1 van 1
      • Unplug the only wire that is connected to the A9 board.
      Vraag FixBot
      Voeg opmerking toe
    12. Yuneec Breeze 4K Camera Replacement: stap 12, afbeelding 1 van 1
      • Pull apart the frame from the other board. The camera will be connected by a plug and it should pull out easily.
      Vraag FixBot
      Voeg opmerking toe
    13. Yuneec Breeze 4K Camera Replacement: stap 13, afbeelding 1 van 1
      • Unscrew the four screws that are holding the camera to the frame.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
Wes Knutson
481 Reputatie
3 handleidingen geschreven
UW Stout, Team S6-G5, Ogden Fall 2018 Lid van UW Stout, Team S6-G5, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G5
4 Leden
4 handleidingen geschreven
1Gids Commentaar
Excellent! I don’t think that the process could of have been any more clear than this.
neonjohn25 - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 38
Altijd: 2,446
