Ga door naar hoofdinhoud
Yobo Gameware Controller Trigger Spring Replacement
Wat je nodig hebt
  1. Yobo Gameware Controller Trigger Spring Replacement, Back Panel: stap 1, afbeelding 1 van 2 Yobo Gameware Controller Trigger Spring Replacement, Back Panel: stap 1, afbeelding 2 van 2
    • Be sure the controller is disconnected from the console or any source of power.
    • Place the controller (button - side down) on a clean, solid work surface.
    • Use your screwdriver to remove the six 9.2mm Tri-wing Y0 screws that hold the back panel in place.
    Vraag FixBot
    Voeg opmerking toe
  2. Yobo Gameware Controller Trigger Spring Replacement, Removing Back Panel: stap 2, afbeelding 1 van 2 Yobo Gameware Controller Trigger Spring Replacement, Removing Back Panel: stap 2, afbeelding 2 van 2
    • Gently life the back panel up, separating it from the front panel.
    • Some components could fall off the front panel if the controller is knocked around during this step.
    Vraag FixBot
    Voeg opmerking toe
  3. Yobo Gameware Controller Trigger Spring Replacement, Removing Triggers: stap 3, afbeelding 1 van 3 Yobo Gameware Controller Trigger Spring Replacement, Removing Triggers: stap 3, afbeelding 2 van 3 Yobo Gameware Controller Trigger Spring Replacement, Removing Triggers: stap 3, afbeelding 3 van 3
    • Depress the trigger assembly using your index finger while using your thumb to keep upward pressure on the grey square bracket and clear circular component on the underside of the trigger assembly.
    • Maintain a firm grip on the entire assembly, as the components could spring apart if you release pressure.
    • Rotate the assembly upwards and towards you to remove it from its housing in the controller.
    • The removal process is the same for both the left and right triggers.
    Vraag FixBot
    Voeg opmerking toe
  4. Yobo Gameware Controller Trigger Spring Replacement, Replacing Spring: stap 4, afbeelding 1 van 2 Yobo Gameware Controller Trigger Spring Replacement, Replacing Spring: stap 4, afbeelding 2 van 2
    • Gently release pressure on the trigger assembly, allowing the components to come apart on your work surface.
    • A new spring may now be incorporated into the designated trigger assembly.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Shoaf
109 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 56
Altijd: 988
