Inleiding
Overheating is a common issue with motorcycles, often caused by cooling fan failure. This problem is easy to fix and requires only a few tools. To complete this repair, you will need a #1 Phillips-head screwdriver, a flat-head screwdriver, and a hex key set, specifically with a 10mm Allen key.
Wat je nodig hebt
Use your motorcycle's key to open the rear seat, and remove the seat to access the tool pouch.
