Ga door naar hoofdinhoud
Xtreme Gaming XG-700 Internal Switch Replacement
Wat je nodig hebt
  1. Xtreme Gaming XG-700 Internal Switch Replacement, Switch: stap 1, afbeelding 1 van 1
    • Flip the mouse over and peel off the two feet at the bottom of the mouse.
    • Using a Phillips #000 screwdriver, remove the two 5.6 mm screws.
  2. Xtreme Gaming XG-700 Internal Switch Replacement: stap 2, afbeelding 1 van 1
    • Carefully separate the base of the mouse from the top case as there are ribbon connectors holding the two pieces together.
    • Don't yank or pull the two pieces apart or you will rip the cables.
  3. Xtreme Gaming XG-700 Internal Switch Replacement: stap 3, afbeelding 1 van 3 Xtreme Gaming XG-700 Internal Switch Replacement: stap 3, afbeelding 2 van 3 Xtreme Gaming XG-700 Internal Switch Replacement: stap 3, afbeelding 3 van 3
    • Carefully remove the two cables from their connection point.
    • The top half of the case can be set aside.
  4. Xtreme Gaming XG-700 Internal Switch Replacement: stap 4, afbeelding 1 van 2 Xtreme Gaming XG-700 Internal Switch Replacement: stap 4, afbeelding 2 van 2
    • Using a small plastic spudger, release the four clips from each corner of the board.
    • Gently remove the board out of the case.
    • Don't yank or pull the board off the case. There is one cable connecting the board to the case.
  5. Xtreme Gaming XG-700 Internal Switch Replacement: stap 5, afbeelding 1 van 1
    • Carefully disconnect the ribbon cable from the board.
    • Set aside the case.
  6. Xtreme Gaming XG-700 Internal Switch Replacement: stap 6, afbeelding 1 van 2 Xtreme Gaming XG-700 Internal Switch Replacement: stap 6, afbeelding 2 van 2
    • Flip the motherboard over, and using a soldering iron, desolder the three switch prongs on each side of the switch.
    • Remove the broken switch.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Nam Nguyen
154 Reputatie
1 Handleiding geschreven
York University, Team M-18, Allen Summer 2022 Lid van York University, Team M-18, Allen Summer 2022
YORK-ALLEN-SU22SMG18
1 Lid
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 56
Altijd: 906
