Inleiding
The robot vacuum tries to dock several times, starts charging, and leaves the dock shortly after.
This behavior repeats several times, until the robot stops with "Error 13 couldn't charge properly" in front of the charging station. (also watch the Video - 3x speed)
Most of the time this is not an issue with the robot but rather of the charging station.
Normally it is done by cleaning the charging contacts on the Robot and the docking station.
If that doesn't fix the problem permanently, it is most likely due to a faulty capacitor.
Known vacuum cleaner robot models/versions with this charging station/dock:
Xiaomi Roborock S5 - series
Xiaomi Roborock S50
Xiaomi Roborock S51
Xiaomi Roborock S52
Xiaomi Roborock S53
Xiaomi Roborock S55
Xiaomi Roborock T61
Xiaomi Roborock T65
Wat je nodig hebt
Video overzicht
Open the screws that hold the board with the screwdriver (2 screws)
Pull the board out carefully, remove the cables from the ducts
Identify the capacitor on the board
Flip the board
Find the contacts on the backside of the board and bridge these with a metal object (for example with tweezers or a screwdriver).
Use the desoldering pump and the soldering iron to unsold the soldering points
Extract the capacitor
Check the nominal value (68uf) of the capacitor compared to your measurement - mind the polarity
Insert new capacitor into the board, mind the polarity
Flip board
Solder capacitor with solder and soldering iron
After cooling, cut off the legs with the side cutter
Work through the Steps 1 and 2 in reverse, to assemble your device again.
13 andere personen hebben deze handleiding voltooid.
Met dank aan deze vertalers:
100%
Deze vertalers helpen ons de wereld te repareren! Wil je bijdragen?
Begin met vertalen ›
48 opmerkingen
420V ELKOs mit 68uf sind praktisch nicht erhältlich. Kann man auch auf einen 400 oder 450 V zurückgreifen? Wenn ja auch welchen? Danke
Hi @danielk223,
ja siehe oben.
Genau deshalb habe ich als Ersatzteil auch schon einen üblicheren angegeben, der funktioniert.
Viel Spaß!
hainzy -
Ah even erst gesehen, vielen Dank. Dann hoffen wir mal, dass das die Lösung ist :)
ELKO ist getauscht, Problem besteht leider weiterhin. Also ist es wohl das Mainboard des Roboters…
Verhält sich der Roboter so wie im Video oder anders?
hainzy -
