Ga door naar hoofdinhoud
Xiaomi Redmi Note Charging Port Replacement
Wat je nodig hebt
    1. Xiaomi Redmi Note Charging Port Replacement, Battery: stap 1, afbeelding 1 van 1
      • Make sure the Xiaomi Redmi Note is powered off before removing the battery.
      • Insert the plastic opening tool between the charging port and the rear case.
      • Pry the end of the rear case up from the charging port.
      Vraag FixBot
      Voeg opmerking toe
    2. Xiaomi Redmi Note Charging Port Replacement: stap 2, afbeelding 1 van 2 Xiaomi Redmi Note Charging Port Replacement: stap 2, afbeelding 2 van 2
      • Run the plastic opening tool along the seam on the side of the phone to remove the rear casing.
      Vraag FixBot
      Voeg opmerking toe
    3. Xiaomi Redmi Note Charging Port Replacement: stap 3, afbeelding 1 van 2 Xiaomi Redmi Note Charging Port Replacement: stap 3, afbeelding 2 van 2
      • Locate the indentation at the bottom of the battery.
      • Place a finger in the indentation and lift up to remove the battery.
      Vraag FixBot
      Voeg opmerking toe
    1. Xiaomi Redmi Note Charging Port Replacement, Midframe: stap 4, afbeelding 1 van 2 Xiaomi Redmi Note Charging Port Replacement, Midframe: stap 4, afbeelding 2 van 2
      • Remove twelve 3.5mm Phillips #00 screws from the midframe.
      Vraag FixBot
      Voeg opmerking toe
    2. Xiaomi Redmi Note Charging Port Replacement: stap 5, afbeelding 1 van 2 Xiaomi Redmi Note Charging Port Replacement: stap 5, afbeelding 2 van 2
      • Insert a plastic opening into the seam between the midframe and the bottom frame of the phone.
      • Run the plastic opening tool along the seam.
      • Pry up the midframe with the plastic opening tool.
      • Once the midframe has been sufficiently lifted with the tool, place a hand underneath the edge to lift the entire component out of the frame.
      • There will be snapping sounds as the clips on the midframe disconnect from the phone.
      Vraag FixBot
      Voeg opmerking toe
    1. Xiaomi Redmi Note Charging Port Replacement, Charging Port: stap 6, afbeelding 1 van 2 Xiaomi Redmi Note Charging Port Replacement, Charging Port: stap 6, afbeelding 2 van 2
      • Locate the charging port panel at the bottom of the device.
      • Remove the 2.9 mm Phillips #00 screws on the sides of the panel.
      Vraag FixBot
      Voeg opmerking toe
    2. Xiaomi Redmi Note Charging Port Replacement: stap 7, afbeelding 1 van 3 Xiaomi Redmi Note Charging Port Replacement: stap 7, afbeelding 2 van 3 Xiaomi Redmi Note Charging Port Replacement: stap 7, afbeelding 3 van 3
      Gereedschap gebruikt in deze stap:
      • Locate the antenna cable at the top right corner of the charging port.
      • Lift the antenna cable off of the panel with tweezers.
      Vraag FixBot
      Voeg opmerking toe
    3. Xiaomi Redmi Note Charging Port Replacement: stap 8, afbeelding 1 van 3 Xiaomi Redmi Note Charging Port Replacement: stap 8, afbeelding 2 van 3 Xiaomi Redmi Note Charging Port Replacement: stap 8, afbeelding 3 van 3
      • Flip the panel to its back side, but do not fully lift it off of the phone yet.
      • Use a plastic opening tool to gently pry off the press fit connector attached to the back side of the panel.
      Vraag FixBot
      Voeg opmerking toe
    4. Xiaomi Redmi Note Charging Port Replacement: stap 9, afbeelding 1 van 1
      • Lift the charging port up to remove it from the frame.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
26 andere personen hebben deze handleiding voltooid.
Caitlin Settles
789 Reputatie
2 handleidingen geschreven
Cal Poly, Team S22-G4, Livingston Spring 2017 Lid van Cal Poly, Team S22-G4, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G4
4 Leden
32 handleidingen geschreven
9Gids Commentaar
Hi, should the battery have a certain time of charge after replacement? Or just start using like everyday, charge when needed?
Luis Amaral - Antwoord Deel
Hi Caitlin, do you know where I can purchase an OEM Charging Port? All I can find is non OEM parts on eBay and parts on witrig. I looked into that site, and it has awful reviews, so I’m not going to try it.
ilikechocobo - Antwoord Deel
hi where can i buy the replacement port charger for the xioami note boo pease
View similar itemsItem - Xiaomi Mi Pad 3 Tablet PC 7.9'' MIUI 8 2.1GHz MT8176 Hexa Core 4GB+64GB WiFi
Brigitte Berkaine-Tongue - Antwoord Deel
How much is it to repair in Qatar riyal
Cynthia - Antwoord Deel
How much does it cost to repair the charging port in Qatar royals?
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 10
Afgelopen 7 dagen: 41
Afgelopen 30 dagen: 179
Altijd: 43,063
