Inleiding
The screen is the output component to present information and is made up of the glass panel, digitizer, and LCD display sandwiched together. If you are experiencing screen issues such as cracked glass, glitchy graphics, colored lines across the panel or unresponsive touch on your Xiaomi Mi A2 (Model M1804D2SG), use this guide to replace the LCD panel (The screen). Before you begin with this guide for a panel that won’t turn on make sure you have checked all possible issues for why a phone won’t output anything, outlined in this guide. If your display is shattered, follow this guide to reinforce your screen to avoid injury until you replace the display.
The replacement part comes with the earpiece speaker and LCD shield plate already installed, making for an easier repair. Before beginning, make sure to power off your phone completely and disconnect from any external power source.
Wat je nodig hebt
Grab a suction cup tool and place it near the bottom of the phone.
Pull up on the suction cup to slightly lift the LCD Panel from the body of the phone.
Starting from the bottom, slide in a plastic opening tool between the gap of the LCD and the phone.
Using a combination of the plastic opening tool and picks, slide around the gaps to unhook the clips, unhinging the panel from the body of the phone.
Flip the phone screen towards the bottom of the device and lay the screen facing down.
Using a plastic spudger remove the battery connector ribbon cable by getting underneath the connector and gently lifting it off.
Using a plastic sudger remove the screen connector ribbon cable by lifting from the underneath.
After you remove the ribbon cable the panel should be free to remove and replace.
13 andere personen hebben deze handleiding voltooid.
Één opmerking
Great guide, thanks!
The only thing, on step # 3 make sure you are removing both frame and display.
First time I by mistake removed display only, and saw quite a different internals (no battery, etc).
