Inleiding
Use this guide to remove or replace a broken rear camera glass in your Xiaomi Mi 9.
You’ll need replacement adhesive to reattach components when reassembling the device.
Wat je nodig hebt
Before you begin, switch off your phone.
Apply a heated iOpener to the rear glass to loosen the adhesive beneath the edges. Apply the iOpener for at least two minutes.
Secure a suction handle to the lower edge of the rear glass, as close to the edge as possible.
Lift the rear glass with the suction handle to create a gap between the glass and the frame.
Insert an opening pick into the gap.
Slide the opening pick to the bottom right corner of the phone.
Remove the ten Phillips #00 screws (3 mm length) that secure the motherboard cover.
Use the flat end of a spudger to pry up and disconnect the sensor cable of the rear camera glass.
Repair didn’t go as planned? Check out our Answers Community for troubleshooting help.
5 andere personen hebben deze handleiding voltooid.
Één opmerking
Hi, I need the part number of the cover with the sensors. The sensors are not working in my device.
