Ga door naar hoofdinhoud
Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement
Wat je nodig hebt
  1. Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement, Insert an opening tool: stap 1, afbeelding 1 van 3 Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement, Insert an opening tool: stap 1, afbeelding 2 van 3 Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement, Insert an opening tool: stap 1, afbeelding 3 van 3
    • Insert an opening tool between the left handle cover and the bottom inner edge of the back housing.
  2. Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement, Release the left handle cover clips: stap 2, afbeelding 1 van 3 Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement, Release the left handle cover clips: stap 2, afbeelding 2 van 3 Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement, Release the left handle cover clips: stap 2, afbeelding 3 van 3
    • Strong plastic clips secure the handle cover. Significant force is required to release them.
    • Slide the opening tool along the inner edge of the left handle cover and pry intermittently to release the plastic clips.
  3. Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement, Remove the left handle cover: stap 3, afbeelding 1 van 3 Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement, Remove the left handle cover: stap 3, afbeelding 2 van 3 Xbox Series X|S Controller (Model 1914) Left Handle Cover Replacement, Remove the left handle cover: stap 3, afbeelding 3 van 3
    • The plastic clips on the outer edge make it difficult to slide along it and release the clips. Therefore, prying up on the inner edge is the easier option.
    • Pry up the middle inner edge of the handle cover with the opening tool to release the remaining clips.
    • Place a finger on top of the handle cover to prevent it from being forcefully ejected.
    • Remove the left handle cover.
    • To reinstall the left handle cover, position it on the back housing and press down firmly along the edges to engage all of the clips.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Manuel Haeussermann
15.592 Reputatie
71 handleidingen geschreven
iFixit Lid van iFixit
Staff
136 Leden
17.430 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 21
Afgelopen 30 dagen: 103
Altijd: 1,206
