Ga door naar hoofdinhoud
Xbox One Wireless Controller Model 1708 Joystick Cap Replacement
Wat je nodig hebt
  1. Xbox One Wireless Controller Model 1708 Joystick Cap Replacement, Cover Plate: stap 1, afbeelding 1 van 2 Xbox One Wireless Controller Model 1708 Joystick Cap Replacement, Cover Plate: stap 1, afbeelding 2 van 2
    • Slide the battery cover toward the top of the controller to remove it.
    • Lift up the batteries or the battery pack from the battery compartment.
  2. Xbox One Wireless Controller Model 1708 Joystick Cap Replacement: stap 2, afbeelding 1 van 2 Xbox One Wireless Controller Model 1708 Joystick Cap Replacement: stap 2, afbeelding 2 van 2
    • Insert a plastic opening tool into the top seam, and gently work the opening tool to the bottom of the controller.
    • Continue using the opening tool to gently pry the side plate off of the controller.
    • Repeat this process for the second side plate.
    Only use a pry tool! The vibration motor wires are exposed and directly accessible from the side when opening. I attempted to open it with a small knife, expecting to be able to gently pry the clips open, accidentally sliced through my right motor’s wires.
    Sawyer Coe - Antwoord
    If you have some Guitar picks laying around they work GREAT!
    Mike Beane - Antwoord
    For some reason, the two closest hinges at the top of the two handle covers are extremely strong. I had to play around to get them off unlike several guides and video tutorials that, I don't know how, take them off without the slightest effort.
    Controller wireless Xbox One Model 1708
    Stefano Spinelli - Antwoord
  3. Xbox One Wireless Controller Model 1708 Joystick Cap Replacement: stap 3, afbeelding 1 van 1
    • Gently peel the battery label or punch a hole in the center of the sticker in the battery compartment to reveal the hidden screw.
    • Remove the five 9mm torx-9 security screws from the back of the controller.
    Torx-8 security bits work as well.
    jahiamir - Antwoord
    Torx 8 or 9 wasn’t working. I used 2.0 minus screwdriver
    richjlee - Antwoord
    The 2.0 minus worked for me as well.
    metric - Antwoord
    When sliding in the plastic cover during reassembly be sure it lines up with the battery compartment contacts. It can be really easy to not see it and bend the contacts. If you still encounter force during this step, depressing the triggers out of the way worked for me.
    Drew - Antwoord
    Since mine is out of warranty I just broke out the security nib with a 2.0 standard bit. Then used a T8 torx.
    Tim LaCrosse - Antwoord
  4. Xbox One Wireless Controller Model 1708 Joystick Cap Replacement: stap 4, afbeelding 1 van 2 Xbox One Wireless Controller Model 1708 Joystick Cap Replacement: stap 4, afbeelding 2 van 2
    • Orient the controller so the front plate is facing up.
    • Lift the front cover off of the controller.
  5. Xbox One Wireless Controller Model 1708 Joystick Cap Replacement: stap 5, afbeelding 1 van 1
    • Turn the controller face down and gently lift the rear plate.
    • Be careful with the rumble motors, as they tend to fall out, risking damage to the motherboard.
    Reassembly: When placing the back cover on: notice that the battery terminals need to slide inside the cover first. Then compress the triggers slightly, Then the cover will be aligned correctly. Then add the front cover and add screws so it doesn’t come undone.
    hunteil - Antwoord
    It isn't necessary to take off the back cover
    Otto Hahn - Antwoord
  6. Xbox One Wireless Controller Model 1708 Joystick Cap Replacement, Tape Shock Motors in place: stap 6, afbeelding 1 van 3 Xbox One Wireless Controller Model 1708 Joystick Cap Replacement, Tape Shock Motors in place: stap 6, afbeelding 2 van 3 Xbox One Wireless Controller Model 1708 Joystick Cap Replacement, Tape Shock Motors in place: stap 6, afbeelding 3 van 3
    • Tape the Rumbler/shock motors in place.
    • This will prevent the motors from falling out.
    if you replace thumbsticks only, this step is NOT required and it is safer not to remove bottom cover, removing faceplate is sufficient to replace thumbsticks
    Piotr Wysocki - Antwoord
  7. Xbox One Wireless Controller Model 1708 Joystick Cap Replacement, Joystick Caps: stap 7, afbeelding 1 van 1
    • Pull the joysticks off of the controller.
    Are the joystick potentiometers soldered to the mother board or just push fit, this guide doesn’t mention soldering so I’m assuming the latter?
    Can you get genuine replacement joystick potentiometers as I’ve only seen cheap eBay type ones?
    Alan - Antwoord
    The actual joysticks themselves are soldered into the bottom motherboard.
    Bryan Remely -
    So where do i get new parts?
    mrdugi - Antwoord
Conclusie
144 andere personen hebben deze handleiding voltooid.
Dylan Gross
4.861 Reputatie
4 handleidingen geschreven
Cal Poly, Team S18-G3, Forte Fall 2017 Lid van Cal Poly, Team S18-G3, Forte Fall 2017
CPSU-FORTE-F17S18G3
4 Leden
34 handleidingen geschreven
9 opmerkingen
How about the square thing with the stick and hinges that the joystick is attached to? I think it’s called the Module. I have a joystick drift / drifting problem and that may help me out. Thanks.
Cory C - Antwoord
Agreed. That’s actually the part I need to replace too. The module.
Thomas Tomchak -
followed this guide to take the controller apart because I had a joystick that was sticking, my solution was to put some 3in1 oil on the module that was sticking and it seems to be working a lot better now.
John Jaggi - Antwoord
@corytc and @tomchak I did replace the module, in general, you buy (Amazon or eBay) you will receive a module of 6 modules you need a multimeter and test each module interface, measure both resistances and subtract them, the one nearest zero is the module you will use since is the one with least drift from the factory.
Just disassemble it, turn upside down uses a solder remover and unsolder the old one, place the new one solder back, boom you are done.
Like you will need an iron solder with medium and thin tips, I used lead-free solder, so is a patience test, be careful with the wires from the rumbles, try not to unsolder them since is a thin wire and is difficult, like I have big hands so took me a while to solder back.
Luis Vitorio Cargnini - Antwoord
Just want to say the hardest part is carefully prying off the plastic covers on the handles. It’s also not necessary to remove the back cover for simply replacing the joysticks. Other than that, it’s very easy. I would guess this is rated at moderate difficulty simply due to the plastic covers.
Will - Antwoord
Exactly! I just replaced thumbsticks without removing bottom cover. Prying grips not not break anything was the hardest part of this repair.
Piotr Wysocki -
Where can one get the replacement joysticks ?
Keven Dubois - Antwoord
I used Ebay and found a few sellers in the USA that had replacement parts for the joystick caps. Color is not the same as the original, but I don't mind this. I recommend typing in your Xbox Controller model number (see inside the battery flap for this) into the online store to see what options are available.
Power Glove -
Just used this guide, thanks @dygross! Some useful tips for others though:
-Torx T9 was not needed. On this model Xbox controller, I used a T8 and did not have any issues as the fit was snug.
-As @ottohahn stated, it is NOT required to take off the rear plate to access the joystick caps. Once you remove the screws on the back of the controller, simply lift the front face plate off and then you can access the joystick and front buttons.
-The plastic side plates are very breakable. They are attached with plastic teeth that need to be carefully pushed in. I thought I did this then realized a small part of one broke off while removing the right-side plate. Take your time and you can totally do this!
Power Glove - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 32
Afgelopen 7 dagen: 275
Afgelopen 30 dagen: 1,553
Altijd: 58,676
