Ga door naar hoofdinhoud
Xbox One Stereo Headset Microphone Replacement
Wat je nodig hebt
  1. Xbox One Stereo Headset Microphone Replacement, Microphone: stap 1, afbeelding 1 van 3 Xbox One Stereo Headset Microphone Replacement, Microphone: stap 1, afbeelding 2 van 3 Xbox One Stereo Headset Microphone Replacement, Microphone: stap 1, afbeelding 3 van 3
    • Use the flat end of a spudger to pry out the rubber stopper at the base of the boom.
  2. Xbox One Stereo Headset Microphone Replacement: stap 2, afbeelding 1 van 1
    • Remove the single 6 mm flathead #2.0 screw exposed after removing the rubber stopper.
  3. Xbox One Stereo Headset Microphone Replacement: stap 3, afbeelding 1 van 1
    • Lift the joint of the boom up and over its pivot point to separate the microphone from the headset.
  4. Xbox One Stereo Headset Microphone Replacement: stap 4, afbeelding 1 van 3 Xbox One Stereo Headset Microphone Replacement: stap 4, afbeelding 2 van 3 Xbox One Stereo Headset Microphone Replacement: stap 4, afbeelding 3 van 3
    • Using the flat end of the metal spudger, pry the back plate off the boom.
    • The back plate is glued to the boom and must be removed gently.
    • When re-installing, apply a few drops of super glue to hold it in place.
  5. Xbox One Stereo Headset Microphone Replacement: stap 5, afbeelding 1 van 1
    • Pull the back plate off the boom.
  6. Xbox One Stereo Headset Microphone Replacement: stap 6, afbeelding 1 van 1
    • Using the flat end of the plastic spudger, gently pry the microphone out of its casing.
    • Desolder the two wires from the back of the microphone. For instructions on how to solder and desolder, please see the soldering technique guide.
    • The white wire connects to the positive node, which is indicated with a "+" on the microphone.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Trevor Steele
233 Reputatie
1 Handleiding geschreven
Cal Poly, Team 17-37, Amido Winter 2015 Lid van Cal Poly, Team 17-37, Amido Winter 2015
CPSU-AMIDO-W15S17G37
4 Leden
5 handleidingen geschreven
9 opmerkingen
Is a replacement microphone available from iFixit?
Scott Minton - Antwoord
What do you replace the mic with?
Its Me - Antwoord
They have the microphone for sale
daniel david guerrerogarcia - Antwoord
Would it presumably be just as easy to replace the microphone speaker with one from another headset, granted it fits ?
harumscxarum - Antwoord
Any mod to make the cable removable?
kikis.andcream - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 32
Altijd: 23,897
