Ga door naar hoofdinhoud
Xbox One Power Brick (Day One Edition) Disassembly
Wat je nodig hebt
  1. Xbox One Power Brick (Day One Edition) Disassembly, Remove Rubber Boots: stap 1, afbeelding 1 van 3 Xbox One Power Brick (Day One Edition) Disassembly, Remove Rubber Boots: stap 1, afbeelding 2 van 3 Xbox One Power Brick (Day One Edition) Disassembly, Remove Rubber Boots: stap 1, afbeelding 3 van 3
    • Unlike the X360 Power Brick, these rubber boots require no tools to pry them up. Simply get your fingernails underneath and gently pull them up.
    • Several people have commented that these boots were much more challenging to remove than mine were.
    • Remove the 4 screws with your T10 security bit driver.
  2. Xbox One Power Brick (Day One Edition) Disassembly, Disconnect Fan Cable: stap 2, afbeelding 1 van 2 Xbox One Power Brick (Day One Edition) Disassembly, Disconnect Fan Cable: stap 2, afbeelding 2 van 2
    • Caution: Be careful not to touch the capacitor wires as you work. If possible, use a capacitor discharge probe to safely rid the capacitors of dangerous charges.
    • Using the point end of your plastic spudger, or your fingers, gently pull back the tab holding the fan power cord in place.
    • Gently pull the cable up and away from the circuit board.
    • If you look inside the yellow box, top left corner, you will notice a grey color on top of a capacitor. I'm not positive what this substance is but it has a consistency of sticky tack, if you remember playing with that as a kid. When I first opened the power supply the fan power cable was pressed into it rendering it stuck. Gently pull the cable up
  3. Xbox One Power Brick (Day One Edition) Disassembly, Remove Screws: stap 3, afbeelding 1 van 3 Xbox One Power Brick (Day One Edition) Disassembly, Remove Screws: stap 3, afbeelding 2 van 3 Xbox One Power Brick (Day One Edition) Disassembly, Remove Screws: stap 3, afbeelding 3 van 3
    • Use a Phillips head screwdriver to remove the two larger screws.
    • The two smaller screws (orange) were a little tricky. They are screwed down very tight. I started with a #0 phillips head and slightly stripped the screw head. Not enough to destroy it. I recommend using a #1 phillips head on these. I also used a small rubber grip in order to get a better grip on my screwdriver. Made it much easier.
    • Once screws are removed lift the plastic frame from the left side and remove it from the top of the power brick and flip it over.
    • Unlike the X360 power brick, the light diffuser does not need to be removed from the power supply. If you want to remove it anyway simply grab it with your fingers and lift it out.
    • When I used a can of air duster to clean the inside, the smaller metal sheet (left side) immediately blew out. If this happens don't panic. There's tape on the bottom side. Simply put it back in with a little pressure to hold it down and you're good to go.
    • These screws serve no purpose. There was nothing under there. Unless you have a different variation than mine there is no need to remove these screws.
  4. Xbox One Power Brick (Day One Edition) Disassembly, Remove Fan From Frame: stap 4, afbeelding 1 van 2 Xbox One Power Brick (Day One Edition) Disassembly, Remove Fan From Frame: stap 4, afbeelding 2 van 2
    • Lift the fan from the side furthest away from the cable.
    • Pull the cable through the hole in the frame and place the fan off to the side.
  5. Xbox One Power Brick (Day One Edition) Disassembly, Disassemble Fan: stap 5, afbeelding 1 van 3 Xbox One Power Brick (Day One Edition) Disassembly, Disassemble Fan: stap 5, afbeelding 2 van 3 Xbox One Power Brick (Day One Edition) Disassembly, Disassemble Fan: stap 5, afbeelding 3 van 3
    • Remove the 4 screws using a #0 Philips head and remove the top of the fan housing.
    • Gently grab the fan and lift it up.
  6. Xbox One Power Brick (Day One Edition) Disassembly, Fan Sticker Info: stap 6, afbeelding 1 van 1
    • Here is the info for the fan label in case anyone needs it for reference.
  7. Xbox One Power Brick (Day One Edition) Disassembly, Care To See What I Initially Found?: stap 7, afbeelding 1 van 3 Xbox One Power Brick (Day One Edition) Disassembly, Care To See What I Initially Found?: stap 7, afbeelding 2 van 3 Xbox One Power Brick (Day One Edition) Disassembly, Care To See What I Initially Found?: stap 7, afbeelding 3 van 3
    • Just under 3 years from the day it was purchased (Nov 22 2013) and now (Aug 12 2016) this is the amount of filth my power brick accumulated. I am only recently getting into electronics repairs which is why this didn't happen sooner.
    • After 1 year your Xbox/PS warranty becomes null and void unless you purchase an extended warranty. Clean your consoles before dirt and dust destroy them!
Eindstreep
87 andere personen hebben deze handleiding voltooid.
Navy Vet 2015
7.296 Reputatie
15 handleidingen geschreven
43 opmerkingen
Would this help with the orange light I am getting from the Xbox one power Brick?
angelorestrepo - Antwoord
Me too having the same question please help!!
kingasd -
Hi! I’ve had many people come to me and ask the same question, if your Xbox One makes a sound when you try to activate it, but there is no light on the Xbox and the power brick is holding a solid orange light, it is most likely the end of your power bricks life. Unfortunately, Microsoft and any other gaming store/supplier stock these anymore, so your last resort would be eBay. 2nd option is if your Xbox doesn’t turn on or make a sound, and your power brick turns white, it’s the console. Long story short, in your situation I would say you might need to invest in a new power brick.
James Byrom -
It is your power brick have too get a new one or change the compasitors there's 3 of them I just had too do it
bryce cowsert -
What specifically is the problem angelorestrepo and kingasd? The orange light is an indicator that your system is in energy saving mode. What happens when you power up the unit?
Navy Vet 2015 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 29
Afgelopen 7 dagen: 273
Afgelopen 30 dagen: 1,362
Altijd: 227,236
