Ga door naar hoofdinhoud
Xbox One Kinect Infrared Camera Replacement
Wat je nodig hebt
  1. Xbox One Kinect Infrared Camera Replacement, Outer Shell: stap 1, afbeelding 1 van 1
    • Remove the sticker on the underside of the device.
    • Remove the four 3.1x23.5 mm T10 screws underneath the sticker.
    • While you're at it, remove the four 3.1x7.5 mm T10 screws beneath the sticker. Make note of the sizes and locations of the screws.
    Vraag FixBot
    Voeg opmerking toe
  2. Xbox One Kinect Infrared Camera Replacement: stap 2, afbeelding 1 van 3 Xbox One Kinect Infrared Camera Replacement: stap 2, afbeelding 2 van 3 Xbox One Kinect Infrared Camera Replacement: stap 2, afbeelding 3 van 3
    • Remove the back panel.
    • Remove the black panels on either side of the Kinect, and remove the 3.1x7.5mm T10 screws underneath them.
    Vraag FixBot
    Voeg opmerking toe
  3. Xbox One Kinect Infrared Camera Replacement: stap 3, afbeelding 1 van 3 Xbox One Kinect Infrared Camera Replacement: stap 3, afbeelding 2 van 3 Xbox One Kinect Infrared Camera Replacement: stap 3, afbeelding 3 van 3
    • Using your thumbs, press firmly against the outer case on either side of the stand. This will disengage the internal assembly.
    • Lift the internal assembly with the spudger.
    • Remove the assembly from the case. You now have access to the inner shell of the kinect, along with the heat sink, microphone, and LED sensor.
    Vraag FixBot
    Voeg opmerking toe
  4. Xbox One Kinect Infrared Camera Replacement, Heat Sink Assembly: stap 4, afbeelding 1 van 2 Xbox One Kinect Infrared Camera Replacement, Heat Sink Assembly: stap 4, afbeelding 2 van 2
    • Remove the eight 2.9x7.6 mm T9 screws from the rear of the internal case.
    • Lift the internal metal case from the plastic shell enclosing the heat sink assembly.
    Vraag FixBot
    Voeg opmerking toe
  5. Xbox One Kinect Infrared Camera Replacement: stap 5, afbeelding 1 van 3 Xbox One Kinect Infrared Camera Replacement: stap 5, afbeelding 2 van 3 Xbox One Kinect Infrared Camera Replacement: stap 5, afbeelding 3 van 3
    • Disconnect the ribbon cable between the sensor driver board and the motherboard.
    • Remove the 3.0x7.5 mm T9 screw holding the sensor driver board to the heat sink.
    • Remove the infrared sensor board for the Kinect.
    Vraag FixBot
    Voeg opmerking toe
  6. Xbox One Kinect Infrared Camera Replacement: stap 6, afbeelding 1 van 3 Xbox One Kinect Infrared Camera Replacement: stap 6, afbeelding 2 van 3 Xbox One Kinect Infrared Camera Replacement: stap 6, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Detach the ribbon cable leading to the microphone with the tweezers.
    • Remove the four 3.1x7.7 mm T9 screws connecting the microphone to the heat sink assembly.
    • Remove the stand.
    Vraag FixBot
    Voeg opmerking toe
  7. Xbox One Kinect Infrared Camera Replacement: stap 7, afbeelding 1 van 3 Xbox One Kinect Infrared Camera Replacement: stap 7, afbeelding 2 van 3 Xbox One Kinect Infrared Camera Replacement: stap 7, afbeelding 3 van 3
    • Remove the eight 3.0x7.6 mm T9 screws from the motherboard.
    • Peel away the plastic film from the motherboard using the spudger.
    • Detach the ribbon cable leading to the color camera using the spudger.
    Vraag FixBot
    Voeg opmerking toe
  8. Xbox One Kinect Infrared Camera Replacement: stap 8, afbeelding 1 van 3 Xbox One Kinect Infrared Camera Replacement: stap 8, afbeelding 2 van 3 Xbox One Kinect Infrared Camera Replacement: stap 8, afbeelding 3 van 3
    • Lift the motherboard and the heat sink assembly from the plastic shell. The components attached to the heat sink are now accessible.
    Vraag FixBot
    Voeg opmerking toe
  9. Xbox One Kinect Infrared Camera Replacement, Infrared Camera: stap 9, afbeelding 1 van 3 Xbox One Kinect Infrared Camera Replacement, Infrared Camera: stap 9, afbeelding 2 van 3 Xbox One Kinect Infrared Camera Replacement, Infrared Camera: stap 9, afbeelding 3 van 3
    • First step is to make sure that the inner compartment containg the camera is separated from the outer casing.
    Vraag FixBot
    Voeg opmerking toe
  10. Xbox One Kinect Infrared Camera Replacement: stap 10, afbeelding 1 van 2 Xbox One Kinect Infrared Camera Replacement: stap 10, afbeelding 2 van 2
    • Once the area where the camera is found is uncovered, use the T5 Torx Screwdriver to remove the four 1.9x10.2 mm screws.
    Vraag FixBot
    Voeg opmerking toe
  11. Xbox One Kinect Infrared Camera Replacement: stap 11, afbeelding 1 van 2 Xbox One Kinect Infrared Camera Replacement: stap 11, afbeelding 2 van 2
    • Using the spudger, detach the camera from the base.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Laura Gonzalez
106 Reputatie
1 Handleiding geschreven
USF Tampa, Team 1-3, Hickman Fall 2014 Lid van USF Tampa, Team 1-3, Hickman Fall 2014
USFT-HICKMAN-F14S1G3
4 Leden
7 handleidingen geschreven
1Gids Commentaar
I have the new Infrared Camera ,1080p HD wide-angle camera,motherboard, IR projectors board.If you need please contact me.
mouyi chen - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 40
Altijd: 2,423
