Ga door naar hoofdinhoud
Xbox One Front Panel Board Replacement
Wat je nodig hebt
  1. Xbox One Front Panel Board Replacement, Upper Case: stap 1, afbeelding 1 van 1
  2. Xbox One Front Panel Board Replacement: stap 2, afbeelding 1 van 2 Xbox One Front Panel Board Replacement: stap 2, afbeelding 2 van 2
    • Use a plastic opening tool to pry up and remove the plastic vent that surrounds the side USB port.
    • The vent is fairly flexible, and held in place with weak plastic clips—start prying from the back and peel it out.
  3. Xbox One Front Panel Board Replacement: stap 3, afbeelding 1 van 2 Xbox One Front Panel Board Replacement: stap 3, afbeelding 2 van 2
    • There is a small plastic tab that reinforces the front corner of the Xbox.
    • Slide the tab straight back and remove it.
  4. Xbox One Front Panel Board Replacement: stap 4, afbeelding 1 van 2 Xbox One Front Panel Board Replacement: stap 4, afbeelding 2 van 2
    • Insert the flat end of a spudger between the upper and lower case where they meet at the rear of the side vent opening.
    • There is a strong plastic clip connecting the two case halves (the first of many), so you'll need to use quite a bit of force.
    • Leave the spudger in place until you open the case completely. The clips are very springy and may cause the case to snap shut while you're working.
  5. Xbox One Front Panel Board Replacement: stap 5, afbeelding 1 van 2 Xbox One Front Panel Board Replacement: stap 5, afbeelding 2 van 2
    • The interface between the upper and lower cases is secured by several clips along the rear and remaining side of the Xbox.
    • Insert a plastic opening tool between the upper and lower case to separate the clip over the rear vent.
  6. Xbox One Front Panel Board Replacement: stap 6, afbeelding 1 van 2 Xbox One Front Panel Board Replacement: stap 6, afbeelding 2 van 2
    • Keep moving along the rear of the Xbox, prying up clips.
    • Make sure the spudger stays in its blocking position—even if the case opens up enough for the spudger to fall out, the remaining clips are springy and may pull the case completely shut. Keep the spudger in the gap to protect your progress.
  7. Xbox One Front Panel Board Replacement: stap 7, afbeelding 1 van 2 Xbox One Front Panel Board Replacement: stap 7, afbeelding 2 van 2
    • Keep popping clips. It may help to slide the plastic opening tool across the clips.
    • By the time you get to the far edge of the rear case, the top case should be ready to come off. If not, run your plastic opening tool around the corner and pop the clips along the side without the USB port.
  8. Xbox One Front Panel Board Replacement: stap 8, afbeelding 1 van 3 Xbox One Front Panel Board Replacement: stap 8, afbeelding 2 van 3 Xbox One Front Panel Board Replacement: stap 8, afbeelding 3 van 3
    • Starting with the spudger you left in the crack, pry the upper case up to free the last few clips.
    • Use a plastic opening tool to pop any straggler clips that weren't freed.
    • Do not try to remove the upper case yet, as it is still connected by the front panel button cable.
    • Lift the upper case slightly and shift it to give access to the front panel board.
  9. Xbox One Front Panel Board Replacement: stap 9, afbeelding 1 van 3 Xbox One Front Panel Board Replacement: stap 9, afbeelding 2 van 3 Xbox One Front Panel Board Replacement: stap 9, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • The front button cable has a unique ZIF connector—pay attention to the next few steps to safely disconnect it.
    • Use tweezers to lift the blue plastic retaining loop over the white connector on the board.
    • Use the tip of a spudger to push the connector's locking tab toward the cable to unlatch it.
  10. Xbox One Front Panel Board Replacement: stap 10, afbeelding 1 van 2 Xbox One Front Panel Board Replacement: stap 10, afbeelding 2 van 2
    • Use tweezers to pull the cable straight out of the connector on the board.
    • Remove the upper case.
  11. Xbox One Front Panel Board Replacement, Reassembly Instructions: stap 11, afbeelding 1 van 3 Xbox One Front Panel Board Replacement, Reassembly Instructions: stap 11, afbeelding 2 van 3 Xbox One Front Panel Board Replacement, Reassembly Instructions: stap 11, afbeelding 3 van 3
    • The next 4 steps are directions for reassembly. Skip them to continue with disassembly.
    • Use the flat end of a spudger to free the clips securing the front panel to the upper case.
    • Remove the front panel from the rest of the upper case.
  12. Xbox One Front Panel Board Replacement: stap 12, afbeelding 1 van 3 Xbox One Front Panel Board Replacement: stap 12, afbeelding 2 van 3 Xbox One Front Panel Board Replacement: stap 12, afbeelding 3 van 3
    • Replace the top part of the upper case.
    • Line up the clips and press firmly to re-seat them around the perimeter.
  13. Xbox One Front Panel Board Replacement: stap 13, afbeelding 1 van 3 Xbox One Front Panel Board Replacement: stap 13, afbeelding 2 van 3 Xbox One Front Panel Board Replacement: stap 13, afbeelding 3 van 3
    • Support the front panel near the front of the Xbox.
    • Use tweezers to replace the front button cable in its ZIF socket.
    • Use the flat end of a spudger to push the ZIF lock to the left to secure the cable.
  14. Xbox One Front Panel Board Replacement: stap 14, afbeelding 1 van 3 Xbox One Front Panel Board Replacement: stap 14, afbeelding 2 van 3 Xbox One Front Panel Board Replacement: stap 14, afbeelding 3 van 3
    • The lower edge of the front panel has plastic hooks that interlock with plastic hooks on the front edge of the lower case.
    • With the front panel at a 45 degree angle, interlock its plastic hooks with those in the lower case.
    • Push the top of the front panel into the Xbox, like closing a mailbox. Press firmly so that the clips securing the front panel to the upper case lock securely.
  15. Xbox One Front Panel Board Replacement, Upper Metal Case: stap 15, afbeelding 1 van 3 Xbox One Front Panel Board Replacement, Upper Metal Case: stap 15, afbeelding 2 van 3 Xbox One Front Panel Board Replacement, Upper Metal Case: stap 15, afbeelding 3 van 3
    • Gently pull up on the speaker cable connector to disconnect it from the front panel board.
    • Be careful to pull up on the cable's connector and not the connector on the board. It's pretty flimsy and you might accidentally pull it off the board entirely.
    • Use the flat end of a spudger to disconnect the antenna cable from the front panel board.
  16. Xbox One Front Panel Board Replacement: stap 16, afbeelding 1 van 3 Xbox One Front Panel Board Replacement: stap 16, afbeelding 2 van 3 Xbox One Front Panel Board Replacement: stap 16, afbeelding 3 van 3
    • Remove the two 9.5 mm T8 Torx screws from the WI-Fi board.
    • Lift the Wi-Fi board straight up from its socket in the upper metal case.
    • Leaving the Wi-Fi board antenna cable in place, move the Wi-Fi board aside, exposing the screw labeled "C3" that was beneath it.
  17. Xbox One Front Panel Board Replacement: stap 17, afbeelding 1 van 1
    • Remove the eight 65 mm Torx T10 screws from the top of the upper metal case.
  18. Xbox One Front Panel Board Replacement: stap 18, afbeelding 1 van 2 Xbox One Front Panel Board Replacement: stap 18, afbeelding 2 van 2
    • Lift—but do not remove—the upper metal case.
    • The Wi-Fi board interconnect cable connects the upper metal case to the motherboard.
  19. Xbox One Front Panel Board Replacement: stap 19, afbeelding 1 van 2 Xbox One Front Panel Board Replacement: stap 19, afbeelding 2 van 2
    • Disconnect the Wi-Fi board interconnect cable from the motherboard.
    • Remove the upper metal case.
  20. Xbox One Front Panel Board Replacement, Hard Drive Assembly: stap 20, afbeelding 1 van 3 Xbox One Front Panel Board Replacement, Hard Drive Assembly: stap 20, afbeelding 2 van 3 Xbox One Front Panel Board Replacement, Hard Drive Assembly: stap 20, afbeelding 3 van 3
    • Disconnect the hard drive SATA power and data cables from the motherboard.
  21. Xbox One Front Panel Board Replacement: stap 21, afbeelding 1 van 1
    • Lift and remove the hard drive tray from the Xbox.
  22. Xbox One Front Panel Board Replacement, Optical Drive Assembly: stap 22, afbeelding 1 van 3 Xbox One Front Panel Board Replacement, Optical Drive Assembly: stap 22, afbeelding 2 van 3 Xbox One Front Panel Board Replacement, Optical Drive Assembly: stap 22, afbeelding 3 van 3
    • Disconnect the optical drive power and SATA data cables from the motherboard.
  23. Xbox One Front Panel Board Replacement: stap 23, afbeelding 1 van 1
    • Remove the optical drive assembly from the Xbox.
  24. Xbox One Front Panel Board Replacement, Front Panel Board: stap 24, afbeelding 1 van 1
    • Lift the motherboard assembly out of the lower case.
  25. Xbox One Front Panel Board Replacement: stap 25, afbeelding 1 van 1
    • Remove the three 9.5 mm T9 Torx screws securing the front panel board.
  26. Xbox One Front Panel Board Replacement: stap 26, afbeelding 1 van 1
    • Disconnect the front panel board from its socket in the front of the motherboard.
Conclusie
26 andere personen hebben deze handleiding voltooid.
Andrew Optimus Goldheart
512.897 Reputatie
407 handleidingen geschreven
iFixit Lid van iFixit
Staff
123 Leden
23.992 handleidingen geschreven
4Gids Commentaar
Hi would you know where I could get that panel from that reienforces my consol
Nelson okanee - Antwoord
Also my button won't work to sync a new controller what part do I get to fix that
I did all that. Put it back together, now i push my power button and it only lights up for a second then dies. The power box and source are good. What did i do wrong?
Chris Chapman - Antwoord
My Xbox turns on and immediately turns back off pls help
gavin moyer - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 13
Afgelopen 7 dagen: 90
Afgelopen 30 dagen: 488
Altijd: 72,358
