Ga door naar hoofdinhoud
Xbox One Elite Controller (Model 1698) Motherboard Replacement
Wat je nodig hebt
  1. Xbox One Elite Controller (Model 1698) Motherboard Replacement, Show me the Screws!: stap 1, afbeelding 1 van 2 Xbox One Elite Controller (Model 1698) Motherboard Replacement, Show me the Screws!: stap 1, afbeelding 2 van 2
    • You can remove the side panels with a pry tool.
    • You don't need to remove the rubber. The rubber on this controller was already bad.
    Vraag FixBot
    Voeg opmerking toe
  2. Xbox One Elite Controller (Model 1698) Motherboard Replacement, Removing the back panel screws: stap 2, afbeelding 1 van 1
    • Remove the 5 Torx Security Bit (TR9) screws.
    Vraag FixBot
    Voeg opmerking toe
  3. Xbox One Elite Controller (Model 1698) Motherboard Replacement, Popping that back panel off: stap 3, afbeelding 1 van 3 Xbox One Elite Controller (Model 1698) Motherboard Replacement, Popping that back panel off: stap 3, afbeelding 2 van 3 Xbox One Elite Controller (Model 1698) Motherboard Replacement, Popping that back panel off: stap 3, afbeelding 3 van 3
    • Pry the panel next to the 3.5mm port.
    • Be careful to not rip the ribbon shown in the next step.
    Vraag FixBot
    Voeg opmerking toe
  4. Xbox One Elite Controller (Model 1698) Motherboard Replacement, Warning Carefully remove the ribbon: stap 4, afbeelding 1 van 2 Xbox One Elite Controller (Model 1698) Motherboard Replacement, Warning Carefully remove the ribbon: stap 4, afbeelding 2 van 2
    • Be careful to not rip the ribbon cable.
    • You can pop the connector up to remove the ribbon easily.
    • Ribbon Cable
    Vraag FixBot
    Voeg opmerking toe
  5. Xbox One Elite Controller (Model 1698) Motherboard Replacement, Screws on controller motherboard: stap 5, afbeelding 1 van 1
    • Remove the 2 Torx (T6) screws.
    Vraag FixBot
    Voeg opmerking toe
  6. Xbox One Elite Controller (Model 1698) Motherboard Replacement, Desolder wires from motherboard: stap 6, afbeelding 1 van 2 Xbox One Elite Controller (Model 1698) Motherboard Replacement, Desolder wires from motherboard: stap 6, afbeelding 2 van 2
    • Desolder the 4 wires on each side, these control the vibrations and the RT LT.
    Vraag FixBot
    Voeg opmerking toe
  7. Xbox One Elite Controller (Model 1698) Motherboard Replacement, Remove the motherboard: stap 7, afbeelding 1 van 2 Xbox One Elite Controller (Model 1698) Motherboard Replacement, Remove the motherboard: stap 7, afbeelding 2 van 2
    • Pull up from the "top" side of the controller on the daughterboard.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
9 andere personen hebben deze handleiding voltooid.
EasyAsABC123
2.557 Reputatie
5 handleidingen geschreven
1Gids Commentaar
50 minutes? half of that tops
glenn.fowell - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 19
Afgelopen 30 dagen: 107
Altijd: 19,343
