Ga door naar hoofdinhoud
Xbox Disc Drive Replacement
Wat je nodig hebt
  1. Xbox Disc Drive Replacement, Hard Drive: stap 1, afbeelding 1 van 1
    • Make sure your Xbox is safely unplugged and is laying on a flat, stable surface.
    Vraag FixBot
    Voeg opmerking toe
  2. Xbox Disc Drive Replacement: stap 2, afbeelding 1 van 1
    • Turn the Xbox over to reveal the four rubber feet.
    • Use a metal spudger to pry off the four rubber feet.
    Vraag FixBot
    Voeg opmerking toe
  3. Xbox Disc Drive Replacement: stap 3, afbeelding 1 van 2 Xbox Disc Drive Replacement: stap 3, afbeelding 2 van 2
    • There are 2 more screws hidden under the two labels on the bottom of the case.
    • You can either remove the labels or simply feel for the screw holes through the labels and then cut or punch a hole through them.
    Vraag FixBot
    Voeg opmerking toe
  4. Xbox Disc Drive Replacement: stap 4, afbeelding 1 van 1
    • Remove the six T20 Torx screws securing the top cover to the bottom cover.
    Vraag FixBot
    Voeg opmerking toe
  5. Xbox Disc Drive Replacement: stap 5, afbeelding 1 van 2 Xbox Disc Drive Replacement: stap 5, afbeelding 2 van 2
    • Once the bottom and top shells are no longer attached, carefully turn the Xbox right-side-up, lift and remove the top cover.
    Vraag FixBot
    Voeg opmerking toe
  6. Xbox Disc Drive Replacement: stap 6, afbeelding 1 van 2 Xbox Disc Drive Replacement: stap 6, afbeelding 2 van 2
    • Remove the three 3 mm T10 screws securing the hard drive to the Xbox.
    • There is one screw on the rear left side of the hard drive that is only visible when the IDE ribbon cable is lifted up. The other two are at the front right and left sides of the hard drive.
    • The screw on the lower left corner of the disk drive is not in the hole that it appears to be in, but rather just closer to the corner.
    Vraag FixBot
    Voeg opmerking toe
  7. Xbox Disc Drive Replacement: stap 7, afbeelding 1 van 2 Xbox Disc Drive Replacement: stap 7, afbeelding 2 van 2
    • Free the hard drive power cable from the carrier for sufficient slack to lift the hard drive out.
    • Lift the plastic hard drive carrier out of the Xbox case.
    Vraag FixBot
    Voeg opmerking toe
  8. Xbox Disc Drive Replacement: stap 8, afbeelding 1 van 3 Xbox Disc Drive Replacement: stap 8, afbeelding 2 van 3 Xbox Disc Drive Replacement: stap 8, afbeelding 3 van 3
    • Remove the four 3.4 mm T15 Torx screws from the plastic hard drive carrier (two screws per side).
    • Carefully remove the hard drive from the plastic carrier. Gentle rocking will see the hard drive come out quite easily.
    Vraag FixBot
    Voeg opmerking toe
  9. Xbox Disc Drive Replacement: stap 9, afbeelding 1 van 2 Xbox Disc Drive Replacement: stap 9, afbeelding 2 van 2
    • Pull both the hard drive data ribbon cable and the power cable straight up from the hard drive.
    • They may be firmly seated, so be careful trying to remove them. DO NOT pull the wires as you may damage the cable assembly.
    Vraag FixBot
    Voeg opmerking toe
  10. Xbox Disc Drive Replacement, Disc Drive: stap 10, afbeelding 1 van 3 Xbox Disc Drive Replacement, Disc Drive: stap 10, afbeelding 2 van 3 Xbox Disc Drive Replacement, Disc Drive: stap 10, afbeelding 3 van 3
    • Remove the disk drive. It should come right out.
    • Unplug the ribbon cable and yellow cables from back of disk drive.
    Vraag FixBot
    Voeg opmerking toe
  11. Xbox Disc Drive Replacement: stap 11, afbeelding 1 van 1
    • Pry back the black plastic tabs around the disk drive in order to remove it from its housing. Once removed, set the drive aside.
    • If you are removing the disk drive in order to gain access to the motherboard underneath, you do not need to remove the plastic housing.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
69 andere personen hebben deze handleiding voltooid.
rmarstel
6.291 Reputatie
5 handleidingen geschreven
Cal Poly, Team 18-2, Maness Fall 2009 Lid van Cal Poly, Team 18-2, Maness Fall 2009
CPSU-MANESS-F09S18G2
3 Leden
26 handleidingen geschreven
8Gids Commentaar
http://www.ebay.com/gds/How-To-Determine...
Utilize the information on this website to determine what Xbox version you have so you know what replacement parts to look for.
Navy Vet 2015 - Antwoord Deel
The final comment mentions “only remove if dead.”   What about a disc drive that closes and opens immediately….in other words, won’t stay closed.  Is this a sign of a defective disc drive too?
Miguel - Antwoord Deel
I am having the same issue, Miguel.
Did you buy a new drive or figure out a better fix?
Thanks
Ben C. - Antwoord Deel
I learned that you need to change out the drive belt in the disc drive. Over time it wears out and either won't open, stays open, or will open/close continuously. I changed my drive belt and it started working fine.
Turtlelaw - Antwoord Deel
Can anyone help..My Xbox can't read games..I took it apart and cleaned it, still can't read games
mr.mistermitchell@yahoo.com - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 18
Afgelopen 7 dagen: 156
Afgelopen 30 dagen: 820
Altijd: 89,982
