Ga door naar hoofdinhoud
Xbox 360 Wireless Controller Buttons Replacement
Wat je nodig hebt
  1. Xbox 360 Wireless Controller Buttons Replacement, Battery: stap 1, afbeelding 1 van 2 Xbox 360 Wireless Controller Buttons Replacement, Battery: stap 1, afbeelding 2 van 2
    • Depress the battery release button on the top of the controller.
    • Remove the battery holder from the controller.
    • The standard option for Xbox 360 Wireless Controllers Battery Packs is AA batteries. A rechargeable battery is also available, but both battery options are removed from the controller in the same way.
    Vraag FixBot
    Voeg opmerking toe
  2. Xbox 360 Wireless Controller Buttons Replacement, Rear Case: stap 2, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Use a pair of tweezers to peel the barcode sticker from the battery compartment.
    Vraag FixBot
    Voeg opmerking toe
  3. Xbox 360 Wireless Controller Buttons Replacement: stap 3, afbeelding 1 van 1
    • Remove the seven 9.3 mm T8 Security Torx screws securing the rear case to the front case.
    Vraag FixBot
    Voeg opmerking toe
  4. Xbox 360 Wireless Controller Buttons Replacement: stap 4, afbeelding 1 van 2 Xbox 360 Wireless Controller Buttons Replacement: stap 4, afbeelding 2 van 2
    Spudger
    $2.99
    • Insert a Spudger between the front and rear cases along the left edge of the controller.
    • Rotate the spudger toward the front of the controller, prying the two cases apart.
    Vraag FixBot
    Voeg opmerking toe
  5. Xbox 360 Wireless Controller Buttons Replacement: stap 5, afbeelding 1 van 2 Xbox 360 Wireless Controller Buttons Replacement: stap 5, afbeelding 2 van 2
    • Insert a spudger between the front and rear cases, near the headphone jack.
    • Rotate the spudger toward the front of the controller to pry the two cases apart.
    Vraag FixBot
    Voeg opmerking toe
  6. Xbox 360 Wireless Controller Buttons Replacement: stap 6, afbeelding 1 van 2 Xbox 360 Wireless Controller Buttons Replacement: stap 6, afbeelding 2 van 2
    • Grasp the controller by the battery compartment and the headphone jack.
    • Lift the battery compartment away from the headphone jack, separating the rear case from the front case and logic board.
    • The battery contact springs are held in place by slots in the battery housing in the rear case. Be sure to realign them properly during reassembly.
    Vraag FixBot
    Voeg opmerking toe
  7. Xbox 360 Wireless Controller Buttons Replacement, Vibration Motors: stap 7, afbeelding 1 van 2 Xbox 360 Wireless Controller Buttons Replacement, Vibration Motors: stap 7, afbeelding 2 van 2
    • Use the flat end of a spudger to remove the vibration motor cable, moving it upward from its socket on the logic board.
    • Lift the vibration motor out of the front case.
    Vraag FixBot
    Voeg opmerking toe
  8. Xbox 360 Wireless Controller Buttons Replacement: stap 8, afbeelding 1 van 2 Xbox 360 Wireless Controller Buttons Replacement: stap 8, afbeelding 2 van 2
    • Remove the vibration motor from the other side of the controller using the same method previously described.
    • The left motor has significantly more counterweight than the right motor.
    Vraag FixBot
    Voeg opmerking toe
  9. Xbox 360 Wireless Controller Buttons Replacement, Logic Board: stap 9, afbeelding 1 van 2 Xbox 360 Wireless Controller Buttons Replacement, Logic Board: stap 9, afbeelding 2 van 2
    • Lifting from the headphone jack and power plug, remove the logic board from the front case.
    Vraag FixBot
    Voeg opmerking toe
  10. Xbox 360 Wireless Controller Buttons Replacement, Buttons: stap 10, afbeelding 1 van 1
    • Remove the rubber pad from the back of the input buttons.
    Vraag FixBot
    Voeg opmerking toe
  11. Xbox 360 Wireless Controller Buttons Replacement: stap 11, afbeelding 1 van 2 Xbox 360 Wireless Controller Buttons Replacement: stap 11, afbeelding 2 van 2
    • Using a pair of tweezers, remove the buttons from the front case.
    • A Button
    • B Button
    • X Button
    • Y Button
    • Start Button
    • Select Button
    • Guide Button
    Vraag FixBot
    Voeg opmerking toe
  12. Xbox 360 Wireless Controller Buttons Replacement: stap 12, afbeelding 1 van 1
    • Using a pair of tweezers, lift the home button's LED ring out of the front case of the controller.
    • All of the buttons have tabs that correspond to slots in the front case. This prevents buttons from being placed in the incorrect position or orientation.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
68 andere personen hebben deze handleiding voltooid.
Brett Hartt
132.207 Reputatie
144 handleidingen geschreven
iFixit Lid van iFixit
Staff
122 Leden
26.715 handleidingen geschreven
3Gids Commentaar
Hello I have had an Xbox for about 1-2years and everything has been working fine until the A button on one of my controllers stopped working I don't think it has gunk or anything because I can press it down and it comes back up just that when I press it in screen nothing happens but the other buttons work fine
Saul Escalon - Antwoord Deel
Thank you for the teardown! My cat has just vomitted on my joystick…. I could have cleaned it now! I appreciate it , thanks…
Nathan St-Onge - Antwoord Deel
Has anyone ever replaced the spring contacts in the logic board???
BJ Robbins - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 77
Afgelopen 30 dagen: 453
Altijd: 78,815
