Ga door naar hoofdinhoud
Xbox 360 HDD Replacement
Wat je nodig hebt
  1. Xbox 360 HDD Replacement, HDD: stap 1, afbeelding 1 van 3 Xbox 360 HDD Replacement, HDD: stap 1, afbeelding 2 van 3 Xbox 360 HDD Replacement, HDD: stap 1, afbeelding 3 van 3
    • Here it is. The standard 20GB HDD for the Xbox 360.
    • Notice the proprietary adapter. Inside is just a pretty standard 2.5" SATA drive...
    • I took these pictures as I was putting it back together, hence the Microsoft warranty sticker looking a little funny.
    • You may also notice the screw in the bottom left is partly out. This is because as I was replacing the screw before it, I broke my bit. I was using a 1/16" flathead bit (I don't have a T6 Torx) and used just a little too much torque and it snapped. I found another 1/16" bit to finish, but didn't get a pic.
    • If you have Torx bits/drivers, use them. They will work much better than the flatheads.
  2. Xbox 360 HDD Replacement: stap 2, afbeelding 1 van 1
    • Remove the Microsoft warranty sticker. I used my fingernail. Note: doing so voids the warranty for the drive, if it is still valid.
    • It only voids the warranty for the drive, not the console, being as their warranties are separate.
    • Proceed to remove the four T6 Torx screws.
  3. Xbox 360 HDD Replacement: stap 3, afbeelding 1 van 3 Xbox 360 HDD Replacement: stap 3, afbeelding 2 van 3 Xbox 360 HDD Replacement: stap 3, afbeelding 3 van 3
    • Holding the drive top up, gently pull the top half up from the bottom half. The back will rotate up as the front is connected by two plastic clips.
    • These clips are most easily undone by rotating the top enclosure to about 30º then lifting it up firmly.
    • Be careful to not let it jerk violently during separation. Once the top is removed, there isn't much of anything holding the latch mechanism in place. It would be a bummer to lose the spring, though getting the latch assembly back in place if it comes out is not too difficult, just don't lose the spring.
  4. Xbox 360 HDD Replacement: stap 4, afbeelding 1 van 1
    • Remove the four T10 Torx screws.
    • Slide the cover towards the back of the enclosure and remove. There is a small dot of lock-tite on each screw, fyi.
  5. Xbox 360 HDD Replacement: stap 5, afbeelding 1 van 2 Xbox 360 HDD Replacement: stap 5, afbeelding 2 van 2
    • Here are the innards in all their glory.
    • The four screws that held the cover on also held the drive in place, so just pull off the SATA connector and the drive is almost free.
  6. Xbox 360 HDD Replacement: stap 6, afbeelding 1 van 1
    • To actually get the drive out, you must bend the back of the plastic part of the bottom enclosure down a little bit. Doing so shouldn't break anything, just don't go overboard and bend it excessively.
  7. Xbox 360 HDD Replacement: stap 7, afbeelding 1 van 3 Xbox 360 HDD Replacement: stap 7, afbeelding 2 van 3 Xbox 360 HDD Replacement: stap 7, afbeelding 3 van 3
    • All the parts disassembled. The adapter cable will probably come out as it doesn't seem to be attached directly, but removing it would have required bending the metal enclosure and I didn't want to mess with that.
    • I thought it interesting to note that the drive runs at 5V 0.62A when the enclosure states 5V 1A. I wonder where the other 380mA are going.
    • Also interesting to note: this is a Seagate drive, while the 250GB drive upgrade I mention in the description requires a WD drive. If I understood correctly, this is because the software to format the drive to be recognized by your 360 is written for the WD firmware.
Conclusie
To reassemble your device, get your new hard drive and follow these instructions in reverse order.
67 andere personen hebben deze handleiding voltooid.
R Trent
2.786 Reputatie
1 Handleiding geschreven
6Gids Commentaar
I happen to have an external HD enclosure (the original HD had a platter crash) that works perfectly to mount the XBox 360 HD to my PC for all sorts of uses, allowing for either USB or external SATA connectivity. :D
nonzerosum - Antwoord
Link to article seems to be down. Any mirrors? It woulb be much appreciated, Thanks
Chris Bersteinsson - Antwoord
Sounds and looks easy enough. But will replacing a 20 go drive with a 250 go drive now need any formatting or can I just plug it in and work?
James Mendez - Antwoord
Hola, buenas tardes, realice todos estos pasos y al instalar el disco no lo reconoce. Probe con otro disco y probe con el mismo que acababa de sacar y no lo reconoce. Enchufe el disco por medio de un cable al USB exterior y si lo reconoce.
Ahora supongo que es un problema en la coneccion del disco en su lugar original, puede ser en el cable o en el enchufe. Lo que quiero saber es si estoy bien orientado, o si existe algo que pase por alto y me esta generando este problema. Gracias
Pablo Farias - Antwoord
solo determitae marche di hardisk funzionano con la xbox 360 in piu devi installare il firmware o il software per farlo riconoscere e questo lo fai da pc ci sono molte guide in merito su youtube ciaooooooo
saxon sax - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 24
Afgelopen 7 dagen: 137
Afgelopen 30 dagen: 641
Altijd: 121,956
