Ga door naar hoofdinhoud
Xbox 360 GPU Heat Sink Replacement
Wat je nodig hebt
  1. Xbox 360 GPU Heat Sink Replacement, Hard Drive: stap 1, afbeelding 1 van 2 Xbox 360 GPU Heat Sink Replacement, Hard Drive: stap 1, afbeelding 2 van 2
    • Grasp the hard drive assembly and press the release button while lifting its front edge.
    • Remove the hard drive assembly from the top vent.
    Vraag FixBot
    Voeg opmerking toe
  2. Xbox 360 GPU Heat Sink Replacement, Bottom Vent: stap 2, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Xbox 360 Opening Tool
    • Stand the console vertically with the bottom edge facing up.
    • Throughout the following opening procedure, the finger of an Xbox 360 opening tool can be used in place of a spudger.
    • Insert the flat end of a spudger or the edge of an Xbox 360 opening tool into the small gap at the front edge of the bottom vent.
    • Pry the front edge of the bottom vent away from the faceplate.
    Vraag FixBot
    Voeg opmerking toe
  3. Xbox 360 GPU Heat Sink Replacement: stap 3, afbeelding 1 van 3 Xbox 360 GPU Heat Sink Replacement: stap 3, afbeelding 2 van 3 Xbox 360 GPU Heat Sink Replacement: stap 3, afbeelding 3 van 3
    • In the next few steps, you will use the tip of a spudger or the finger of an Xbox 360 opening tool to release the clips along the left and right sides of the bottom vent. Their locations are highlighted in red.
    • You will insert the tool into the holes molded into the white plastic side case pieces.
    Vraag FixBot
    Voeg opmerking toe
  4. Xbox 360 GPU Heat Sink Replacement: stap 4, afbeelding 1 van 2 Xbox 360 GPU Heat Sink Replacement: stap 4, afbeelding 2 van 2
    • To release the clips, work from the front edge of the bottom vent.
    • While slightly lifting the front edge of the bottom vent, use the tip of a spudger to push the clips closest to the front of the bottom vent towards the inside of the console.
    Vraag FixBot
    Voeg opmerking toe
  5. Xbox 360 GPU Heat Sink Replacement: stap 5, afbeelding 1 van 2 Xbox 360 GPU Heat Sink Replacement: stap 5, afbeelding 2 van 2
    • Repeat the same process to release the two center clips on the bottom vent.
    Vraag FixBot
    Voeg opmerking toe
  6. Xbox 360 GPU Heat Sink Replacement: stap 6, afbeelding 1 van 2 Xbox 360 GPU Heat Sink Replacement: stap 6, afbeelding 2 van 2
    • Use the tip of your spudger to release the clips on the bottom vent nearest the back of the Xbox.
    Vraag FixBot
    Voeg opmerking toe
  7. Xbox 360 GPU Heat Sink Replacement: stap 7, afbeelding 1 van 1
    • Remove the bottom vent from the 360.
    Vraag FixBot
    Voeg opmerking toe
  8. Xbox 360 GPU Heat Sink Replacement, Faceplate: stap 8, afbeelding 1 van 2 Xbox 360 GPU Heat Sink Replacement, Faceplate: stap 8, afbeelding 2 van 2
    • Insert the flat edge of a spudger between the faceplate and the outer casing near the power button.
    • Run your spudger along the edge of the faceplate to release the clips securing it to the front of the console.
    • You may also accomplish this task by using the edge of the Xbox 360 opening tool, but it may scratch the plastic case.
    • Alternatively, you can use your hands to carefully pull the faceplate away from the Xbox.
    Vraag FixBot
    Voeg opmerking toe
  9. Xbox 360 GPU Heat Sink Replacement: stap 9, afbeelding 1 van 1
    • Repeat the same motions as previously mentioned to release the left side of the faceplate.
    Vraag FixBot
    Voeg opmerking toe
  10. Xbox 360 GPU Heat Sink Replacement: stap 10, afbeelding 1 van 1
    • Remove the faceplate from the front face of the console.
    Vraag FixBot
    Voeg opmerking toe
  11. Xbox 360 GPU Heat Sink Replacement, Top Vent: stap 11, afbeelding 1 van 2 Xbox 360 GPU Heat Sink Replacement, Top Vent: stap 11, afbeelding 2 van 2
    • Stand the console vertically with the top edge facing up.
    • The top vent is secured to the console via clips. The first two clips are located underneath the top vent closest to the faceplate, as shown in the pictures.
    Vraag FixBot
    Voeg opmerking toe
  12. Xbox 360 GPU Heat Sink Replacement: stap 12, afbeelding 1 van 2 Xbox 360 GPU Heat Sink Replacement: stap 12, afbeelding 2 van 2
    • Insert the flat end of a spudger into the small gaps previously mentioned to release the clips.
    • You may also use the long finger of an Xbox 360 opening tool to accomplish this task.
    Vraag FixBot
    Voeg opmerking toe
  13. Xbox 360 GPU Heat Sink Replacement: stap 13, afbeelding 1 van 3 Xbox 360 GPU Heat Sink Replacement: stap 13, afbeelding 2 van 3 Xbox 360 GPU Heat Sink Replacement: stap 13, afbeelding 3 van 3
    • In the next few steps, you will use the tip of a spudger or the finger of an Xbox 360 opening tool to release the clips along the left and right sides of the top vent. Their locations are highlighted in red.
    Vraag FixBot
    Voeg opmerking toe
  14. Xbox 360 GPU Heat Sink Replacement: stap 14, afbeelding 1 van 2 Xbox 360 GPU Heat Sink Replacement: stap 14, afbeelding 2 van 2
    • To release the clips, work from the middle of the top vent.
    • While slightly lifting the front edge of the top vent, use the tip of a spudger to push the clips closest to the center of the top vent towards the inside of the console.
    Vraag FixBot
    Voeg opmerking toe
  15. Xbox 360 GPU Heat Sink Replacement: stap 15, afbeelding 1 van 1
    • Use the tip of your spudger to release the clip on the top vent nearest the back of the Xbox's upper case.
    Vraag FixBot
    Voeg opmerking toe
  16. Xbox 360 GPU Heat Sink Replacement: stap 16, afbeelding 1 van 2 Xbox 360 GPU Heat Sink Replacement: stap 16, afbeelding 2 van 2
    • The last clip is hidden underneath the rubber foot nearest the back of the console.
    • Use the tip of your spudger to release the clip on the top vent nearest the back of the Xbox.
    • Remove the top vent from the 360.
    Vraag FixBot
    Voeg opmerking toe
  17. Xbox 360 GPU Heat Sink Replacement, Lower Case: stap 17, afbeelding 1 van 1
    • Stand the console vertically with the top edge facing down.
    • Carefully peel the warranty sticker off the console.
    Vraag FixBot
    Voeg opmerking toe
  18. Xbox 360 GPU Heat Sink Replacement: stap 18, afbeelding 1 van 3 Xbox 360 GPU Heat Sink Replacement: stap 18, afbeelding 2 van 3 Xbox 360 GPU Heat Sink Replacement: stap 18, afbeelding 3 van 3
    • The upper and lower cases are attached via several latches, located in the front and back of the console. These latches must be disengaged to separate the upper case from the console.
    • Use the flat end of a spudger to release the following latches:
    • Above the front-facing USB ports.
    • Beneath the front-facing USB ports.
    • Above the Memory Unit slots.
    Vraag FixBot
    Voeg opmerking toe
  19. Xbox 360 GPU Heat Sink Replacement: stap 19, afbeelding 1 van 1
    • Insert the flat end of a spudger and pry upwards to release the last remaining latch located above the eject button.
    Vraag FixBot
    Voeg opmerking toe
  20. Xbox 360 GPU Heat Sink Replacement: stap 20, afbeelding 1 van 1
    • Slightly lift the front portion of the lower case to ensure that the latches in the front have been completely released.
    Vraag FixBot
    Voeg opmerking toe
  21. Xbox 360 GPU Heat Sink Replacement: stap 21, afbeelding 1 van 2 Xbox 360 GPU Heat Sink Replacement: stap 21, afbeelding 2 van 2
    • The upper and lower cases are held together by seven release latches located on the back of the console. Their locations are highlighted in red.
    Vraag FixBot
    Voeg opmerking toe
  22. Xbox 360 GPU Heat Sink Replacement: stap 22, afbeelding 1 van 3 Xbox 360 GPU Heat Sink Replacement: stap 22, afbeelding 2 van 3 Xbox 360 GPU Heat Sink Replacement: stap 22, afbeelding 3 van 3
    • Press the Xbox 360 opening tool down into the clips securing the lower case to the upper case near the I/O ports.
    • While pressing down on the tool, push the lower and upper cases apart to separate the retaining clips.
    Vraag FixBot
    Voeg opmerking toe
  23. Xbox 360 GPU Heat Sink Replacement: stap 23, afbeelding 1 van 2 Xbox 360 GPU Heat Sink Replacement: stap 23, afbeelding 2 van 2
    • While pushing the upper and lower cases apart, use the tip of a spudger or the finger of an Xbox 360 opening tool to push the long clip highlighted in red toward the center of the 360.
    • The clip should release, leaving the clips near the power connector as the only thing holding the upper and lower cases together.
    Vraag FixBot
    Voeg opmerking toe
  24. Xbox 360 GPU Heat Sink Replacement: stap 24, afbeelding 1 van 1
    • Press the Xbox 360 opening tool down into the two remaining clips near the power connector.
    • Push the upper and lower cases apart to fully release the retaining clips.
    Vraag FixBot
    Voeg opmerking toe
  25. Xbox 360 GPU Heat Sink Replacement: stap 25, afbeelding 1 van 1
    • Orient the console so that the front portion is facing downwards.
    • Grasp the back portion of the lower case and lift it upwards to separate it from the console.
    • Be careful not to excessively bend the lower case near the power plug, as it can crack easily.
    Vraag FixBot
    Voeg opmerking toe
  26. Xbox 360 GPU Heat Sink Replacement, Eject Button: stap 26, afbeelding 1 van 2 Xbox 360 GPU Heat Sink Replacement, Eject Button: stap 26, afbeelding 2 van 2
    • Use the tip of a spudger to release the clip securing the eject button to the metal casing.
    • Insert the flat end of a spudger between the eject button and the optical drive.
    • Pry the eject button off its retaining posts and remove it from the 360.
    • This can also be accomplished using an Xbox 360 opening tool.
    Vraag FixBot
    Voeg opmerking toe
  27. Xbox 360 GPU Heat Sink Replacement, Upper Case: stap 27, afbeelding 1 van 1
    • Remove the six silver 64 mm T10 Torx screws securing the upper case to the metal casing.
    Vraag FixBot
    Voeg opmerking toe
  28. Xbox 360 GPU Heat Sink Replacement: stap 28, afbeelding 1 van 1
    • Orient the console so that the upper case is facing upwards.
    • Lift the upper case straight up and remove it from the console.
    Vraag FixBot
    Voeg opmerking toe
  29. Xbox 360 GPU Heat Sink Replacement, Optical Drive: stap 29, afbeelding 1 van 1
    • Peel the silver tape securing the optical drive to the metal casing.
    Vraag FixBot
    Voeg opmerking toe
  30. Xbox 360 GPU Heat Sink Replacement: stap 30, afbeelding 1 van 1
    • Slightly lift the optical drive upwards to gain clearance to disconnect the SATA and power connectors located on the backside of the optical drive.
    • Don't try to completely remove the optical drive just yet. Two cables still connect it to the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  31. Xbox 360 GPU Heat Sink Replacement: stap 31, afbeelding 1 van 2 Xbox 360 GPU Heat Sink Replacement: stap 31, afbeelding 2 van 2
    • Grab the power connector by its cables and pull it straight out of its socket on the optical drive.
    • Disconnect the SATA data connector from its socket on the optical drive by pulling it straight away.
    Vraag FixBot
    Voeg opmerking toe
  32. Xbox 360 GPU Heat Sink Replacement: stap 32, afbeelding 1 van 1
    • Lift the optical drive assembly out of the metal casing.
    Vraag FixBot
    Voeg opmerking toe
  33. Xbox 360 GPU Heat Sink Replacement, Cooling Fan Duct: stap 33, afbeelding 1 van 2 Xbox 360 GPU Heat Sink Replacement, Cooling Fan Duct: stap 33, afbeelding 2 van 2
    • Insert the flat end of a spudger into the small rectangular opening on the top of the cooling fan duct.
    • Carefully release the fan duct retaining clip and remove the fan duct from the Xbox.
    • The clip can alternatively be released using the metal finger of an Xbox 360 opening tool.
    Vraag FixBot
    Voeg opmerking toe
  34. Xbox 360 GPU Heat Sink Replacement, Dual Fans: stap 34, afbeelding 1 van 2 Xbox 360 GPU Heat Sink Replacement, Dual Fans: stap 34, afbeelding 2 van 2
    • While lifting the metal chassis strip above the dual fans, pull the fans toward the center of the motherboard.
    • Do not completely remove the dual fan assembly yet. Its cable is still attached to the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  35. Xbox 360 GPU Heat Sink Replacement: stap 35, afbeelding 1 van 1
    • Lift the dual fan connector straight up from its socket on the motherboard.
    • Some fan connectors have a locking tab. If yours has a locking tab, be sure to depress it while disconnecting the fan from the motherboard.
    • Remove the dual fan assembly from the console.
    Vraag FixBot
    Voeg opmerking toe
  36. Xbox 360 GPU Heat Sink Replacement, Motherboard: stap 36, afbeelding 1 van 3 Xbox 360 GPU Heat Sink Replacement, Motherboard: stap 36, afbeelding 2 van 3 Xbox 360 GPU Heat Sink Replacement, Motherboard: stap 36, afbeelding 3 van 3
    • Use the flat end of a spudger to release the clips securing the RF module shield along the top and the left edge of the RF module.
    • It may be easier to use your fingernail to release the clips from the RF module.
    • Remove the RF module shield from the console.
    Vraag FixBot
    Voeg opmerking toe
  37. Xbox 360 GPU Heat Sink Replacement: stap 37, afbeelding 1 van 1
    • Remove three 5.6 mm T8 Torx screws securing the RF module to the metal chassis.
    Vraag FixBot
    Voeg opmerking toe
  38. Xbox 360 GPU Heat Sink Replacement: stap 38, afbeelding 1 van 2 Xbox 360 GPU Heat Sink Replacement: stap 38, afbeelding 2 van 2
    • Grasp the RF module and lift it straight up to disconnect it from its socket on the motherboard.
    • Remove the RF module from the console.
    Vraag FixBot
    Voeg opmerking toe
  39. Xbox 360 GPU Heat Sink Replacement: stap 39, afbeelding 1 van 1
    • Remove the following screws securing the motherboard to the metal casing:
    • Nine gold 11 mm T10 Torx screws.
    • Eight black 5.6 mm T8 Torx screws.
    • If you are reassembling your Xbox 360 after installing the Red Ring of Death Fix Kit, the eight T8 Torx screws circled in orange are not reused.
    Vraag FixBot
    Voeg opmerking toe
  40. Xbox 360 GPU Heat Sink Replacement: stap 40, afbeelding 1 van 2 Xbox 360 GPU Heat Sink Replacement: stap 40, afbeelding 2 van 2
    • Turn the Xbox over, being careful not to let the motherboard fall out of the chassis.
    • Lift the motherboard assembly from its front edge.
    • Be careful not to damage the sockets as you rotate the motherboard away from the metal casing.
    • Remove the motherboard assembly from the metal casing.
    Vraag FixBot
    Voeg opmerking toe
  41. Xbox 360 GPU Heat Sink Replacement, GPU Heat Sink: stap 41, afbeelding 1 van 1
    • Insert the tip of a small flathead screwdriver between the X clamp and its retaining post on the heat sink.
    • Pry the X clamp away from its retaining post until it is lifted above the small groove cut into the retaining post.
    Vraag FixBot
    Voeg opmerking toe
  42. Xbox 360 GPU Heat Sink Replacement: stap 42, afbeelding 1 van 2 Xbox 360 GPU Heat Sink Replacement: stap 42, afbeelding 2 van 2
    • Insert your screwdriver parallel to the motherboard between the X clamp and its retaining post.
    • Twist the screwdriver to fully release the X clamp from its retaining post.
    • Repeat this process for all four corners of the X clamp.
    • When removing the last corner of the X clamp and holding the motherboard upside down, be sure to catch the GPU heat sink to avoid damage from it falling.
    Vraag FixBot
    Voeg opmerking toe
  43. Xbox 360 GPU Heat Sink Replacement: stap 43, afbeelding 1 van 1
    • To reinstall the X clamp, first start by attaching two corners to the posts on the heat sink.
    • While holding the third arm of the X clamp down against the post attached to the heat sink, use a small flathead screwdriver to pry the X clamp away from the heat sink post.
    • As you pry, press down on the arm of the X clamp until you "walk" it down into the retaining groove cut into the post attached to the heat sink.
    • Repeat this process for the fourth arm of the X clamp.
    Vraag FixBot
    Voeg opmerking toe
  44. Xbox 360 GPU Heat Sink Replacement: stap 44, afbeelding 1 van 1
    • Remove the GPU heat sink.
    • Before reinstalling the GPU heat sink, be sure to apply a new layer of thermal paste.
    • If you need to mount the heat sink back onto the motherboard, we have a thermal paste guide that makes replacing the thermal compound easy.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
66 andere personen hebben deze handleiding voltooid.
2Gids Commentaar
This guide is very inssuficient. Before you try this, find another guide
nick svensson - Antwoord Deel
I work with many different types of mobile electronics. The tools required section is great. The walkthrough claims to visit their site for upto date info. For a free guide this exceeded my expectations for certain. They could use a little section tab to see videos as that helps the diy ppl learn by examples.
Daniel Dollive - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 59
Afgelopen 30 dagen: 312
Altijd: 109,166
