Ga door naar hoofdinhoud
Xbox 360 E Button Board Replacement
Wat je nodig hebt
  1. Xbox 360 E Button Board Replacement, Top Panel: stap 1, afbeelding 1 van 1
    • Push the Spudger into the crevice between the grated top panel of the Xbox and the bottom body with the rubber feet.
    • Pull back on the spudger like a lever, keeping it pressed firmly into the crevice.
    Vraag FixBot
    Voeg opmerking toe
  2. Xbox 360 E Button Board Replacement: stap 2, afbeelding 1 van 1
    • Slide the spudger along the separation you have created between the grated panel and the bottom body of the Xbox.
    • Periodically pull back on the spudger like a lever, keeping it pressed firmly into the crevice.
    Vraag FixBot
    Voeg opmerking toe
  3. Xbox 360 E Button Board Replacement: stap 3, afbeelding 1 van 3 Xbox 360 E Button Board Replacement: stap 3, afbeelding 2 van 3 Xbox 360 E Button Board Replacement: stap 3, afbeelding 3 van 3
    • Continue sliding the spudger along the perimeter of the left grated face of the Xbox.
    • Pull the top panel off.
    Vraag FixBot
    Voeg opmerking toe
  4. Xbox 360 E Button Board Replacement, Bottom Panel: stap 4, afbeelding 1 van 1
    • Push the spudger into the crevice between the right grated face and the top body of the Xbox. It's easier to begin away from the vent.
    • Pull up on the spudger like a lever, keeping it pressed firmly into the crevice.
    Vraag FixBot
    Voeg opmerking toe
  5. Xbox 360 E Button Board Replacement: stap 5, afbeelding 1 van 2 Xbox 360 E Button Board Replacement: stap 5, afbeelding 2 van 2
    • Slide the spudger along the crevice to separate the grated face and the top body.
    Vraag FixBot
    Voeg opmerking toe
  6. Xbox 360 E Button Board Replacement: stap 6, afbeelding 1 van 3 Xbox 360 E Button Board Replacement: stap 6, afbeelding 2 van 3 Xbox 360 E Button Board Replacement: stap 6, afbeelding 3 van 3
    • Wiggle the spudger in the crevice as you slide the spudger to loosen the bottom plate.
    • Slide the spudger along the crevice, going completely about the perimeter of the bottom panel.
    • Pull the bottom panel off.
    Vraag FixBot
    Voeg opmerking toe
  7. Xbox 360 E Button Board Replacement, Front Panel: stap 7, afbeelding 1 van 3 Xbox 360 E Button Board Replacement, Front Panel: stap 7, afbeelding 2 van 3 Xbox 360 E Button Board Replacement, Front Panel: stap 7, afbeelding 3 van 3
    • In front of the CD drive you will find the Xbox logo. Press on the area left of the Xbox logo, and the disk tray panel will pop off.
    Vraag FixBot
    Voeg opmerking toe
  8. Xbox 360 E Button Board Replacement: stap 8, afbeelding 1 van 3 Xbox 360 E Button Board Replacement: stap 8, afbeelding 2 van 3 Xbox 360 E Button Board Replacement: stap 8, afbeelding 3 van 3
    • Beginning on the left side without the grate, run the spudger along the crevice until you've reached the grated part, while holding the part that's being separated as you go.
    Vraag FixBot
    Voeg opmerking toe
  9. Xbox 360 E Button Board Replacement: stap 9, afbeelding 1 van 3 Xbox 360 E Button Board Replacement: stap 9, afbeelding 2 van 3 Xbox 360 E Button Board Replacement: stap 9, afbeelding 3 van 3
    • Keep holding the partially separated panel open. It's easiest to do this by wedging a spudger into the opening but can also be held open by your hands.
    • Rotate the Xbox to the left to locate the clip connecting the front panel to the body. Insert the spudger inside the gap to release the clip. This may require wiggling the spudger. The clip will pop off, making the front panel looser.
    Vraag FixBot
    Voeg opmerking toe
  10. Xbox 360 E Button Board Replacement: stap 10, afbeelding 1 van 3 Xbox 360 E Button Board Replacement: stap 10, afbeelding 2 van 3 Xbox 360 E Button Board Replacement: stap 10, afbeelding 3 van 3
    • Flip the Xbox so the opposite side is towards you. Make sure to keep the separation open.
    • Locate the other clip and insert the spudger to remove it.
    Vraag FixBot
    Voeg opmerking toe
  11. Xbox 360 E Button Board Replacement: stap 11, afbeelding 1 van 2 Xbox 360 E Button Board Replacement: stap 11, afbeelding 2 van 2
    • Continue to run the spudger along the crease to release any further clips that may still be attatched.
    • Do not pull off the panel too fast because you don't want to damage the ribbon cable. Slowly pull away the panel.
    • Now that the front panel has been released from its clips you can pull off the front panel.
    Vraag FixBot
    Voeg opmerking toe
  12. Xbox 360 E Button Board Replacement: stap 12, afbeelding 1 van 3 Xbox 360 E Button Board Replacement: stap 12, afbeelding 2 van 3 Xbox 360 E Button Board Replacement: stap 12, afbeelding 3 van 3
    • Find the brown section where the ribbon cable enters the green board. Flip the brown part up and pull out the plastic tab at the end of the ribbon.
    Vraag FixBot
    Voeg opmerking toe
  13. Xbox 360 E Button Board Replacement, Button Board: stap 13, afbeelding 1 van 3 Xbox 360 E Button Board Replacement, Button Board: stap 13, afbeelding 2 van 3 Xbox 360 E Button Board Replacement, Button Board: stap 13, afbeelding 3 van 3
    • Rotate the front panel so you are looking at the inside of the piece.
    • Unscrew the six 6 mm screws with the T6 Torx screwdriver.
    • Carefully pull the green plate up and off to remove it.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
14 andere personen hebben deze handleiding voltooid.
Jennifer
2.194 Reputatie
4 handleidingen geschreven
Cal Poly, Team 2-11, Amido Winter 2014 Lid van Cal Poly, Team 2-11, Amido Winter 2014
CPSU-AMIDO-W14S2G11
4 Leden
44 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 37
Afgelopen 30 dagen: 213
Altijd: 15,101
