Ga door naar hoofdinhoud
Xbox 360 Bottom Vent Replacement
Wat je nodig hebt
  1. Xbox 360 Bottom Vent Replacement, Bottom Vent: stap 1, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Xbox 360 Opening Tool
    • Stand the console vertically with the bottom edge facing up.
    • Throughout the following opening procedure, the finger of an Xbox 360 opening tool can be used in place of a spudger.
    • Insert the flat end of a spudger or the edge of an Xbox 360 opening tool into the small gap at the front edge of the bottom vent.
    • Pry the front edge of the bottom vent away from the faceplate.
    You can avoid this step by pulling the front cover off. Just make sure you don't break the springs for the USB bay area.
    Repair Doctor - Antwoord
    Hello, thank you ifix for this guide, I followed this guide, I got stuck at some point but I resolved it. Also I want to share this resource: Step by Step guide to fix Xbox 360 errors it helped me go through all the things associated with Xbox 360 and the troubleshooting of errors. Hope this can also help you all.
    Christopher Sage - Antwoord
  2. Xbox 360 Bottom Vent Replacement: stap 2, afbeelding 1 van 3 Xbox 360 Bottom Vent Replacement: stap 2, afbeelding 2 van 3 Xbox 360 Bottom Vent Replacement: stap 2, afbeelding 3 van 3
    • In the next few steps, you will use the tip of a spudger or the finger of an Xbox 360 opening tool to release the clips along the left and right sides of the bottom vent. Their locations are highlighted in red.
    • You will insert the tool into the holes molded into the white plastic side case pieces.
  3. Xbox 360 Bottom Vent Replacement: stap 3, afbeelding 1 van 2 Xbox 360 Bottom Vent Replacement: stap 3, afbeelding 2 van 2
    • To release the clips, work from the front edge of the bottom vent.
    • While slightly lifting the front edge of the bottom vent, use the tip of a spudger to push the clips closest to the front of the bottom vent towards the inside of the console.
  4. Xbox 360 Bottom Vent Replacement: stap 4, afbeelding 1 van 2 Xbox 360 Bottom Vent Replacement: stap 4, afbeelding 2 van 2
    • Repeat the same process to release the two center clips on the bottom vent.
  5. Xbox 360 Bottom Vent Replacement: stap 5, afbeelding 1 van 2 Xbox 360 Bottom Vent Replacement: stap 5, afbeelding 2 van 2
    • Use the tip of your spudger to release the clips on the bottom vent nearest the back of the Xbox.
  6. Xbox 360 Bottom Vent Replacement: stap 6, afbeelding 1 van 1
    • Remove the bottom vent from the 360.
Conclusie
68 andere personen hebben deze handleiding voltooid.
Één opmerking
cool thanks for the tip
exavier smith - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 12
Afgelopen 7 dagen: 26
Afgelopen 30 dagen: 69
Altijd: 28,918
