Ga door naar hoofdinhoud
X-Treme Tablet Generation 2 Battery Replacement
Wat je nodig hebt
  1. X-Treme Tablet Generation 2 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Start on the edge of the top corner and use a spudger opening tool to carefully pry the back cover off of the main body.
    • Continue prying around the device, being careful to not dislodge the power button.
  2. X-Treme Tablet Generation 2 Battery Replacement: stap 2, afbeelding 1 van 3 X-Treme Tablet Generation 2 Battery Replacement: stap 2, afbeelding 2 van 3 X-Treme Tablet Generation 2 Battery Replacement: stap 2, afbeelding 3 van 3
    • Pull the cloth tape from the battery to free the body of the battery.
    • Use a solder vacuum and soldering iron to release the red, and then the black, wire from the motherboard.
  3. X-Treme Tablet Generation 2 Battery Replacement: stap 3, afbeelding 1 van 2 X-Treme Tablet Generation 2 Battery Replacement: stap 3, afbeelding 2 van 2
    • Remove the battery from the device.
    • Insert the new 3.7 V Li-Polymer battery into the device.
    • Use the soldering iron to solder the red, and then the black, wire back to motherboard.
    • Check out our How to Solder and Desolder Connections guide for help with soldering best practices.
Conclusie
Mike Longshore
125 Reputatie
1 Handleiding geschreven
Pasco Hernando, Team 5-4, Prince Winter 2015 Lid van Pasco Hernando, Team 5-4, Prince Winter 2015
PHSC-PRINCE-W15S5G4
6 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 6
Altijd: 1,096
