Ga door naar hoofdinhoud
Wolf Gourmet WGTR102S Electrical Connection Replacement
Wat je nodig hebt
    1. Wolf Gourmet WGTR102S Electrical Connection Replacement, Outer Shell: stap 1, afbeelding 1 van 1
      • Using a wedge, pry off the rubber pieces on the bottom of each foot of the toaster.
      Vraag FixBot
      Voeg opmerking toe
    2. Wolf Gourmet WGTR102S Electrical Connection Replacement: stap 2, afbeelding 1 van 1
      • Remove the eight 8mm screws on each toaster foot using a Tri-point Y1 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    3. Wolf Gourmet WGTR102S Electrical Connection Replacement: stap 3, afbeelding 1 van 1
      • Remove the crumb collector located on the bottom of the toaster.
      Vraag FixBot
      Voeg opmerking toe
    4. Wolf Gourmet WGTR102S Electrical Connection Replacement: stap 4, afbeelding 1 van 1
      • Remove the three 8mm screws using the Tri-point Y1 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    5. Wolf Gourmet WGTR102S Electrical Connection Replacement: stap 5, afbeelding 1 van 1
      • Remove the two 8mm screws on the bottom of the slide lever using a Tri-point Y1 screwdriver.
      • Once the screws are removed, detach the black plastic cover on the bottom of the slide lever.
      Vraag FixBot
      Voeg opmerking toe
    6. Wolf Gourmet WGTR102S Electrical Connection Replacement: stap 6, afbeelding 1 van 1
      • Remove the final 8mm screw in the slide lever.
      • The lever can now pull away from the entire unit.
      Vraag FixBot
      Voeg opmerking toe
    7. Wolf Gourmet WGTR102S Electrical Connection Replacement: stap 7, afbeelding 1 van 1
      • Remove toaster's outer shell by lifting straight up.
      • Slowly remove the outer shell. Disconnect ground wire before fully separating the shell and inner components.
      Vraag FixBot
      Voeg opmerking toe
    8. Wolf Gourmet WGTR102S Electrical Connection Replacement: stap 8, afbeelding 1 van 2 Wolf Gourmet WGTR102S Electrical Connection Replacement: stap 8, afbeelding 2 van 2
      • Disconnect the wire cluster that connects the lights and circuit board by pulling apart the two plastic connectors.
      • Remove the outer shell from the device.
      Vraag FixBot
      Voeg opmerking toe
    1. Wolf Gourmet WGTR102S Electrical Connection Replacement, Electrical Connection: stap 9, afbeelding 1 van 1
      • Unscrew the ground wire using a Tri-point Y1 screwdriver. It is secured with an 8mm screw.
      Vraag FixBot
      Voeg opmerking toe
    2. Wolf Gourmet WGTR102S Electrical Connection Replacement: stap 10, afbeelding 1 van 1
      • Use pliers to pull apart the three electrical connectors pictured in the graphic.
      Vraag FixBot
      Voeg opmerking toe
    3. Wolf Gourmet WGTR102S Electrical Connection Replacement: stap 11, afbeelding 1 van 1
      • Replace the electrical connectors.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Ryan Funchess
715 Reputatie
5 handleidingen geschreven
Cal Poly, Team S22-G5, Maness Spring 2018 Lid van Cal Poly, Team S22-G5, Maness Spring 2018
CPSU-MANESS-S18S22G5
4 Leden
10 handleidingen geschreven
1Gids Commentaar
Ryan Funchess
Thank you for you work on this toaster. My customer is happy.
Adam Hunsinger - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 40
Altijd: 1,405
