Ga door naar hoofdinhoud
Withings Smart Body Analyzer Motherboard Replacement
Wat je nodig hebt
    1. Withings Smart Body Analyzer Motherboard Replacement, Withings Smart Body Analyzer Disassembly: stap 1, afbeelding 1 van 1
      • Push the battery door
      • Open the compartment
      • Gently remove the batteries from their designated positions
      • Place them aside, away from the reach of children
      Vraag FixBot
      Voeg opmerking toe
    2. Withings Smart Body Analyzer Motherboard Replacement: stap 2, afbeelding 1 van 3 Withings Smart Body Analyzer Motherboard Replacement: stap 2, afbeelding 2 van 3 Withings Smart Body Analyzer Motherboard Replacement: stap 2, afbeelding 3 van 3
      • With caution, insert the plastic opening tools in between the disk and the glass face
      • It's a tight fit, so don't be afraid to apply a little bit of force
      • As soon as you hear a faint crackling sound, that means that the adhesive is budging out of place
      • Gently rotate the plastic spudger around the disk to get around the adhesive
      • Gently lift the metal disk
      • After the disk has been lifted, a wire and a small copper plate can be seen attached to the back of the disk
      • Carefully remove the wire and plate by peeling back the adhesive sticker that has been positioned around them
      Vraag FixBot
      Voeg opmerking toe
    3. Withings Smart Body Analyzer Motherboard Replacement: stap 3, afbeelding 1 van 2 Withings Smart Body Analyzer Motherboard Replacement: stap 3, afbeelding 2 van 2
      • After all the above steps have been completed, proceed by removing the glass face
      • Carefully insert a plasic spudger in the small gap that exist in between the glass face and the plastic back
      • Run the plastic spudger all around the scale to increase the gap size
      • Place a plastic spudger in every corner, since the feet of the scale are also attached to the glass face using adhesive
      • Carefully insert the metal spudger underneath the adhesive that is located underneath the feet of the scale, and gently keep pushing until the adhesive is out of place
      • Repeat the above steps four times
      • After all the adhesives has been removed, gently lift the glass face off
      Vraag FixBot
      Voeg opmerking toe
    1. Withings Smart Body Analyzer Motherboard Replacement, Motherboard: stap 4, afbeelding 1 van 2 Withings Smart Body Analyzer Motherboard Replacement, Motherboard: stap 4, afbeelding 2 van 2
      • Using the Phillips-head screwdriver, unscrew the two screws that are securing the motherboard in place
      Vraag FixBot
      Voeg opmerking toe
    2. Withings Smart Body Analyzer Motherboard Replacement: stap 5, afbeelding 1 van 1
      • Using a plastic spudger, disconnect the LCD display's ribbon cable from the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    3. Withings Smart Body Analyzer Motherboard Replacement: stap 6, afbeelding 1 van 1
      • Once the two screws and the ribbon cable are detached, remove the motherboard.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
Ashley Dauphinee
323 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team S4-G1, Julie Spring 2017 Lid van UMass Dartmouth, Team S4-G1, Julie Spring 2017
UMASSD-JULIE-S17S4G1
4 Leden
5 handleidingen geschreven
2Gids Commentaar
My Wifi Body scale cannot connect to Wifi or my app. Everything else works. Where can I have it repaired. Please advise.
Mel - Antwoord Deel
where do you get the motherboard?
cost?
donald taylor - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 28
Afgelopen 30 dagen: 129
Altijd: 8,092
