Ga door naar hoofdinhoud
Wire Bonder Thread Spool Replacement
Video overzicht
    1. Wire Bonder Thread Spool Replacement, Wire Bonder Thread Spool Replacement: stap 1, afbeelding 1 van 1
      • Remove the seal from the wire spool. Take care not to cut the thread at the red marking!
      Vraag FixBot
      Voeg opmerking toe
    2. Wire Bonder Thread Spool Replacement: stap 2, afbeelding 1 van 1
      • Insert the spool in the assembly.
      • Make sure that the spool runs clockwise.
      Vraag FixBot
      Voeg opmerking toe
      • Pull the thread downward.
      Vraag FixBot
      Voeg opmerking toe
    3. Wire Bonder Thread Spool Replacement, Placing the thread into the infeeder: stap 4, afbeelding 1 van 1
      • Place the thread between the guides of the infeeder.
      • Pull the engaging knob which is situated to the left of the infeeder rolls, to the left.
      • Now there is a gap between the infeeder rolls into which the wire can be inserted safely.
      Vraag FixBot
      Voeg opmerking toe
    4. Wire Bonder Thread Spool Replacement, Placing the thread behind the sensors: stap 5, afbeelding 1 van 1
      • Cut the wire.
      • Place the wire behind the sensors (the black box in the foreground).
      Vraag FixBot
      Voeg opmerking toe
    5. Wire Bonder Thread Spool Replacement, Placing the thrad in the outfeeder: stap 6, afbeelding 1 van 1
      Gereedschap gebruikt in deze stap:
      • Use the tweezers to place the wire between the two metal guides of the outfeeder.
      Vraag FixBot
      Voeg opmerking toe
    6. Wire Bonder Thread Spool Replacement, Put the wire into the tube: stap 7, afbeelding 1 van 1
      • Use the tweezers to lead the wire into the tube from below.
      Vraag FixBot
      Voeg opmerking toe
    7. Wire Bonder Thread Spool Replacement, Automatic feeding: stap 8, afbeelding 1 van 1
      • Push the spring of the outfeeder and the "Feed and Capture" button simultaneously for automatic feeding.
      • Make sure that the rolls of the outfeeder are close together so that the wire is gripped firmly.
      • Before starting automatic feeding, turn off "Run or Service" and activate "Feed or Capture".
      Vraag FixBot
      Voeg opmerking toe
    8. Wire Bonder Thread Spool Replacement, Manual Feeding: stap 9, afbeelding 1 van 2 Wire Bonder Thread Spool Replacement, Manual Feeding: stap 9, afbeelding 2 van 2
      • It is also possible to feed the wire manually into the outfeeder tube.
      • In order to do so, press the "Run and Service" button and turn the left-hand wheel clockwise. The wire is now fed ino the tube.
      Vraag FixBot
      Voeg opmerking toe
    9. Wire Bonder Thread Spool Replacement: stap 10, afbeelding 1 van 1
      • Check visually if the wire is fed into the bonding head.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Beate Richter
181 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 28
Altijd: 375
