Inleiding
To complete this guide, you will need to take apart the tablet almost completely.
Wat je nodig hebt
Un-stick the battery from the motherboard assembly with the plastic opening tool.
Stap 6 Motherboard
Voorzichtig: stappen 6-10 komen van een handleiding die in bewerking is.
Locate each of the motherboard's 4 mm screws.
Remove each of the four 4 mm screws from the motherboard pictured to the left.
Use a Phillips #00 precision screwdriver.
Use the spudger to pry the instrument array from its plastic housing.
There are two additional 4 mm screws holding the front screen.
Use the Phillips #00 screwdriver to remove the screws (pictured to the left).
Één opmerking
Hi, have a Filemate tablet and the front is broke . So is the Front and Digitizer the same thing? Thank you Brenda L Glidewell
