Inleiding
To complete this guide, you will need steady hands to remove and replace the motherboard.
Wat je nodig hebt
Un-stick the battery from the motherboard assembly with the plastic opening tool.
Remove each of the four 4 mm screws from the motherboard pictured to the left.
Use a Phillips #00 precision screwdriver.
Use the spudger to pry the instrument array from its plastic housing.
Bijna klaar!
Conclusie
