Ga door naar hoofdinhoud
Whirlpool Washing Machine Lid Lock Assembly Replacement
Video Gids
Deze gids is getranscribeerd van een YouTube-video.
Wat je nodig hebt
      • Unplug the washing machine from the wall and close both water supply valves.
      • Slide the washer forward so you can reach the back panel comfortably.
      Vraag FixBot
      Voeg opmerking toe
      • Remove the two quarter-inch screws at the back corners that secure the top panel.
      • Remove the quarter-inch screw in the small wire-harness cover and lift the cover off.
      Vraag FixBot
      Voeg opmerking toe
      • Remove the five screws holding the rear console cover and pull the metal cover away.
      Vraag FixBot
      Voeg opmerking toe
      • Push the basket rearward, reach under the lid, and press the two hidden spring clips to pop the console loose, or slide a flexible plastic card into the gap from the front to release them.
      • Avoid metal tools because they scratch the plastic trim badly.
      • Swing the console up, press the tab on its single wire connector, and unplug it from the control board.
      Vraag FixBot
      Voeg opmerking toe
      • Unplug the lid-lock harness and any other wiring leading into the top panel.
      • Pull the small pressure hose straight off its port on the control board.
      • Remove the green ground strap held by a quarter-inch screw if it blocks the panel.
      Vraag FixBot
      Voeg opmerking toe
      • Raise the rear edge of the lid and top assembly high, push it forward to free the rear clips, then move to the front and lift upward while pulling back to release the front tabs.
      • Pivot the entire top toward the rear wall and rest its edges in the two metal fingers on the chassis so it cannot fall.
      Vraag FixBot
      Voeg opmerking toe
      • Slip a fingernail or thin plastic tool under the bezel tabs on the lid surface and gently pry it free from the lock body.
      • The bezel is thin and cracks easily, so work slowly and do not twist hard.
      Vraag FixBot
      Voeg opmerking toe
      • Push the lock assembly to the left, lift it slightly, then slide it right and out of the lid opening.
      Vraag FixBot
      Voeg opmerking toe
      • Use a flat-blade screwdriver to pry the two metal retainers open and pull the harness trunk out of them.
      • Press the tab on the small plastic retainer and release the harness from the top side of the lid.
      Vraag FixBot
      Voeg opmerking toe
      • Thread the replacement harness through the lid hole and seat it into the two metal clips.
      • Snap the plastic retainer back into the lid to secure the harness slack.
      Vraag FixBot
      Voeg opmerking toe
      • Insert the top of the lock body into the left side of the opening, press it flush against the lid, and slide it firmly to the right until the side tab clicks.
      Vraag FixBot
      Voeg opmerking toe
      • Align the bezel over the lock and press until all four tabs click flat against the lid surface.
      • If the bezel will not seat, the lock is not fully latched into its housing.
      Vraag FixBot
      Voeg opmerking toe
      • Guide the top back onto the chassis, rock it forward, down, and back until the front and rear clips snap flush.
      • Lift the rear edge again slightly if needed to be sure every latch is locked tight.
      Vraag FixBot
      Voeg opmerking toe
      • Reinstall the green ground strap with its screw and plug every harness back into the control board.
      • Set the console on its hinges and push until the spring clips click into the lid housing.
      Vraag FixBot
      Voeg opmerking toe
      • Install the metal console back cover with its five screws.
      • Replace the wire-harness cover screw, then reinstall the two quarter-inch top screws removed earlier.
      Vraag FixBot
      Voeg opmerking toe
      • Open the water supply valves and plug the washer back into the outlet.
      Vraag FixBot
      Voeg opmerking toe
      • Verify all lights are off, then press the same three keys in order three times within eight seconds (1-2-3, 1-2-3, 1-2-3) to enter diagnostics.
      • Wait for the indicator lamps to flash, press the second key (Rinse) once, then press Start to launch the automatic test cycle for calibration.
      • Allow about five minutes for the test to complete and confirm proper lock operation.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Repair didn't go as planned? Ask our Answers community for help.
Ben Schlichter
7.128 Reputatie
224 handleidingen geschreven
1Gids Commentaar
What do u do wen the 123 123 123 method dose not work... ??
JORDAN M M PELLETIER - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 24
Afgelopen 30 dagen: 126
Altijd: 718
