Ga door naar hoofdinhoud
Whirlpool Refrigerator Temperature Control Board Replacement
Wat je nodig hebt
  1. Whirlpool Refrigerator Temperature Control Board Replacement, Safety precautions: stap 1, afbeelding 1 van 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Temperature Control Board Replacement, Open the doors: stap 2, afbeelding 1 van 3 Whirlpool Refrigerator Temperature Control Board Replacement, Open the doors: stap 2, afbeelding 2 van 3 Whirlpool Refrigerator Temperature Control Board Replacement, Open the doors: stap 2, afbeelding 3 van 3
    • Depending on your repair, open one or both doors.
  3. Whirlpool Refrigerator Temperature Control Board Replacement, Unfasten the temperature control board assembly: stap 3, afbeelding 1 van 2 Whirlpool Refrigerator Temperature Control Board Replacement, Unfasten the temperature control board assembly: stap 3, afbeelding 2 van 2
    • Remove the screw(s) securing the temperature control board assembly.
    • The second photo shows the potential screw locations in a removed assembly.
  4. Whirlpool Refrigerator Temperature Control Board Replacement, Reposition the assembly: stap 4, afbeelding 1 van 3 Whirlpool Refrigerator Temperature Control Board Replacement, Reposition the assembly: stap 4, afbeelding 2 van 3 Whirlpool Refrigerator Temperature Control Board Replacement, Reposition the assembly: stap 4, afbeelding 3 van 3
    • Pull the temperature control board assembly off its slot in the chassis.
    • Let the assembly hang to access its connectors.
  5. Whirlpool Refrigerator Temperature Control Board Replacement, Disconnect the temperature control board: stap 5, afbeelding 1 van 3 Whirlpool Refrigerator Temperature Control Board Replacement, Disconnect the temperature control board: stap 5, afbeelding 2 van 3 Whirlpool Refrigerator Temperature Control Board Replacement, Disconnect the temperature control board: stap 5, afbeelding 3 van 3
    • Disconnect any connectors attached to the temperature control board assembly.
  6. Whirlpool Refrigerator Temperature Control Board Replacement, Remove the assembly: stap 6, afbeelding 1 van 1
    • Remove the temperature control board assembly.
  7. Whirlpool Refrigerator Temperature Control Board Replacement, Separate the temperature control board: stap 7, afbeelding 1 van 3 Whirlpool Refrigerator Temperature Control Board Replacement, Separate the temperature control board: stap 7, afbeelding 2 van 3 Whirlpool Refrigerator Temperature Control Board Replacement, Separate the temperature control board: stap 7, afbeelding 3 van 3
    • Use a flathead screwdriver, or a similar tool, to compress the plastic clip securing the temperature control board.
    • Use another flathead screwdriver to pry up the board from its housing.
  8. Whirlpool Refrigerator Temperature Control Board Replacement, Remove the temperature control board: stap 8, afbeelding 1 van 1
    • Pull the temperature control board straight out of its housing to remove it.
Conclusie
Repair didn’t go as planned? Ask our Answers community for help.
nicO
15.945 Reputatie
89 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 41
Altijd: 1,942
