Ga door naar hoofdinhoud
Whirlpool Refrigerator Icemaker Assembly Replacement
Wat je nodig hebt
  1. Whirlpool Refrigerator Icemaker Assembly Replacement, Safety precautions: stap 1, afbeelding 1 van 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Icemaker Assembly Replacement, Open the doors: stap 2, afbeelding 1 van 3 Whirlpool Refrigerator Icemaker Assembly Replacement, Open the doors: stap 2, afbeelding 2 van 3 Whirlpool Refrigerator Icemaker Assembly Replacement, Open the doors: stap 2, afbeelding 3 van 3
    • Depending on your repair, open one or both doors.
  3. Whirlpool Refrigerator Icemaker Assembly Replacement, Remove the icemaker tray: stap 3, afbeelding 1 van 2 Whirlpool Refrigerator Icemaker Assembly Replacement, Remove the icemaker tray: stap 3, afbeelding 2 van 2
    • Pull the icemaker tray completely out of its slot in the chassis.
  4. Whirlpool Refrigerator Icemaker Assembly Replacement, Unfasten the icemaker assembly: stap 4, afbeelding 1 van 2 Whirlpool Refrigerator Icemaker Assembly Replacement, Unfasten the icemaker assembly: stap 4, afbeelding 2 van 2
    • Remove the screw(s) securing the icemaker assembly.
    • The second photo shows the potential screw locations in a removed icemaker assembly.
  5. Whirlpool Refrigerator Icemaker Assembly Replacement, Reposition the icemaker assembly: stap 5, afbeelding 1 van 3 Whirlpool Refrigerator Icemaker Assembly Replacement, Reposition the icemaker assembly: stap 5, afbeelding 2 van 3 Whirlpool Refrigerator Icemaker Assembly Replacement, Reposition the icemaker assembly: stap 5, afbeelding 3 van 3
    • Pull the icemaker assembly off its slot in the chassis.
    • Let the assembly hang to access its connectors.
  6. Whirlpool Refrigerator Icemaker Assembly Replacement, Disconnect the icemaker assembly: stap 6, afbeelding 1 van 3 Whirlpool Refrigerator Icemaker Assembly Replacement, Disconnect the icemaker assembly: stap 6, afbeelding 2 van 3 Whirlpool Refrigerator Icemaker Assembly Replacement, Disconnect the icemaker assembly: stap 6, afbeelding 3 van 3
    • Disconnect any connectors attached to the icemaker assembly.
  7. Whirlpool Refrigerator Icemaker Assembly Replacement, Remove the icemaker assembly: stap 7, afbeelding 1 van 1
    • Remove the icemaker assembly.
Conclusie
Repair didn’t go as planned? Ask our Answers community for help.
Één andere persoon heeft deze handleiding voltooid.
nicO
15.945 Reputatie
89 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 45
Afgelopen 30 dagen: 226
Altijd: 7,578
