Ga door naar hoofdinhoud
Whirlpool Refrigerator Evaporator Fan Replacement
Wat je nodig hebt
  1. Whirlpool Refrigerator Evaporator Fan Replacement, Safety precautions: stap 1, afbeelding 1 van 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Evaporator Fan Replacement, Open the doors: stap 2, afbeelding 1 van 3 Whirlpool Refrigerator Evaporator Fan Replacement, Open the doors: stap 2, afbeelding 2 van 3 Whirlpool Refrigerator Evaporator Fan Replacement, Open the doors: stap 2, afbeelding 3 van 3
    • Depending on your repair, open one or both doors.
  3. Whirlpool Refrigerator Evaporator Fan Replacement, Remove the drawers: stap 3, afbeelding 1 van 2 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the drawers: stap 3, afbeelding 2 van 2
    • Remove the drawers and shelves from the freezer section.
  4. Whirlpool Refrigerator Evaporator Fan Replacement: stap 4, afbeelding 1 van 2 Whirlpool Refrigerator Evaporator Fan Replacement: stap 4, afbeelding 2 van 2
    • Remove the screw(s) securing the evaporator cover.
  5. Whirlpool Refrigerator Evaporator Fan Replacement, Unclip the evaporator cover: stap 5, afbeelding 1 van 3 Whirlpool Refrigerator Evaporator Fan Replacement, Unclip the evaporator cover: stap 5, afbeelding 2 van 3 Whirlpool Refrigerator Evaporator Fan Replacement, Unclip the evaporator cover: stap 5, afbeelding 3 van 3
    • Lift the bottom of the evaporator cover up and over its lip in the chassis.
    • Pull the cover toward yourself to release its top clips.
  6. Whirlpool Refrigerator Evaporator Fan Replacement, Remove the evaporator cover: stap 6, afbeelding 1 van 3 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the evaporator cover: stap 6, afbeelding 2 van 3 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the evaporator cover: stap 6, afbeelding 3 van 3
    • Continue pulling the evaporator cover towards yourself to unclip its metal prongs from the chassis.
    • Remove the evaporator cover.
  7. Whirlpool Refrigerator Evaporator Fan Replacement, Disconnect the evaporator fan: stap 7, afbeelding 1 van 2 Whirlpool Refrigerator Evaporator Fan Replacement, Disconnect the evaporator fan: stap 7, afbeelding 2 van 2
    • Use needle nose pliers, or your fingers, to disconnect the grounding wire(s) attached to the evaporator fan.
  8. Whirlpool Refrigerator Evaporator Fan Replacement: stap 8, afbeelding 1 van 3 Whirlpool Refrigerator Evaporator Fan Replacement: stap 8, afbeelding 2 van 3 Whirlpool Refrigerator Evaporator Fan Replacement: stap 8, afbeelding 3 van 3
    • Disconnect any connectors attached to the evaporator fan.
  9. Whirlpool Refrigerator Evaporator Fan Replacement, Unfasten the evaporator fan: stap 9, afbeelding 1 van 1
    • Remove the screw(s) securing the evaporator fan.
  10. Whirlpool Refrigerator Evaporator Fan Replacement, Remove the foam buffers: stap 10, afbeelding 1 van 3 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the foam buffers: stap 10, afbeelding 2 van 3 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the foam buffers: stap 10, afbeelding 3 van 3
    • Slide the foam buffer downward to release it from its lip in the chassis.
    • Remove the foam buffer.
    • Repeat this procedure any remaining foam buffers.
  11. Whirlpool Refrigerator Evaporator Fan Replacement, Remove the evaporator fan housing: stap 11, afbeelding 1 van 3 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the evaporator fan housing: stap 11, afbeelding 2 van 3 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the evaporator fan housing: stap 11, afbeelding 3 van 3
    • Pull the evaporator fan housing up and outward from the chassis to remove it.
  12. Whirlpool Refrigerator Evaporator Fan Replacement, Remove the fan: stap 12, afbeelding 1 van 2 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the fan: stap 12, afbeelding 2 van 2
    • Pull the evaporator fan straight off its motor to remove it.
    • This may require some significant force.
  13. Whirlpool Refrigerator Evaporator Fan Replacement, Remove the motor bracket: stap 13, afbeelding 1 van 3 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the motor bracket: stap 13, afbeelding 2 van 3 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the motor bracket: stap 13, afbeelding 3 van 3
    • Use your fingers to pry up and release the motor bracket clips from the housing.
  14. Whirlpool Refrigerator Evaporator Fan Replacement, Remove the motor bracket: stap 14, afbeelding 1 van 2 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the motor bracket: stap 14, afbeelding 2 van 2
    • Remove the motor bracket.
  15. Whirlpool Refrigerator Evaporator Fan Replacement, Remove the motor: stap 15, afbeelding 1 van 3 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the motor: stap 15, afbeelding 2 van 3 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the motor: stap 15, afbeelding 3 van 3
    • Pull the motor straight out of its housing to remove it.
Conclusie
Repair didn’t go as planned? Ask our Answers community for help.
Één andere persoon heeft deze handleiding voltooid.
nicO
15.927 Reputatie
88 handleidingen geschreven
Global Fixers Lid van Global Fixers
Community
35 Leden
603 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 12
Afgelopen 7 dagen: 67
Afgelopen 30 dagen: 463
Altijd: 4,697
