Ga door naar hoofdinhoud
Whirlpool Refrigerator Drain Pan Replacement
Wat je nodig hebt
  1. Whirlpool Refrigerator Drain Pan Replacement, Safety precautions: stap 1, afbeelding 1 van 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Drain Pan Replacement, Open the doors: stap 2, afbeelding 1 van 3 Whirlpool Refrigerator Drain Pan Replacement, Open the doors: stap 2, afbeelding 2 van 3 Whirlpool Refrigerator Drain Pan Replacement, Open the doors: stap 2, afbeelding 3 van 3
    • Depending on your repair, open one or both doors.
  3. Whirlpool Refrigerator Drain Pan Replacement, Unfasten the front panel: stap 3, afbeelding 1 van 3 Whirlpool Refrigerator Drain Pan Replacement, Unfasten the front panel: stap 3, afbeelding 2 van 3 Whirlpool Refrigerator Drain Pan Replacement, Unfasten the front panel: stap 3, afbeelding 3 van 3
    • Remove the screw(s) securing the front panel.
  4. Whirlpool Refrigerator Drain Pan Replacement, Remove the front panel: stap 4, afbeelding 1 van 3 Whirlpool Refrigerator Drain Pan Replacement, Remove the front panel: stap 4, afbeelding 2 van 3 Whirlpool Refrigerator Drain Pan Replacement, Remove the front panel: stap 4, afbeelding 3 van 3
    • Pull the front panel straight off the chassis and remove it.
    • You may have to slightly open the water filter door to remove the front panel completely.
  5. Whirlpool Refrigerator Drain Pan Replacement, Unfasten the wiring harness: stap 5, afbeelding 1 van 1
    • Use a 1/4 inch socket wrench to remove the 16.7 mm-long screw securing the wiring harness.
  6. Whirlpool Refrigerator Drain Pan Replacement, Reposition the wiring harness: stap 6, afbeelding 1 van 2 Whirlpool Refrigerator Drain Pan Replacement, Reposition the wiring harness: stap 6, afbeelding 2 van 2
    • Pull the wiring harness out of its slot in the chassis to access its connectors.
  7. Whirlpool Refrigerator Drain Pan Replacement, Disconnect the wiring harness: stap 7, afbeelding 1 van 3 Whirlpool Refrigerator Drain Pan Replacement, Disconnect the wiring harness: stap 7, afbeelding 2 van 3 Whirlpool Refrigerator Drain Pan Replacement, Disconnect the wiring harness: stap 7, afbeelding 3 van 3
    • Disconnect the two connectors attached to the door wiring harness.
  8. Whirlpool Refrigerator Drain Pan Replacement, Unfasten the rear panel: stap 8, afbeelding 1 van 3 Whirlpool Refrigerator Drain Pan Replacement, Unfasten the rear panel: stap 8, afbeelding 2 van 3 Whirlpool Refrigerator Drain Pan Replacement, Unfasten the rear panel: stap 8, afbeelding 3 van 3
    • Remove the screw(s) securing the rear panel.
    • Loosen the screw securing the water hose enough for the rear panel to freely move.
  9. Whirlpool Refrigerator Drain Pan Replacement, Remove the rear panel: stap 9, afbeelding 1 van 3 Whirlpool Refrigerator Drain Pan Replacement, Remove the rear panel: stap 9, afbeelding 2 van 3 Whirlpool Refrigerator Drain Pan Replacement, Remove the rear panel: stap 9, afbeelding 3 van 3
    • Pull the rear panel off the chassis to remove it.
  10. Whirlpool Refrigerator Drain Pan Replacement, Remove the condenser fan: stap 10, afbeelding 1 van 3 Whirlpool Refrigerator Drain Pan Replacement, Remove the condenser fan: stap 10, afbeelding 2 van 3 Whirlpool Refrigerator Drain Pan Replacement, Remove the condenser fan: stap 10, afbeelding 3 van 3
    • Put on gloves before continuing, as the sheet metal and the condenser fan itself are sharp.
    • Pull the condenser fan straight off its peg to remove it.
  11. Whirlpool Refrigerator Drain Pan Replacement, Unclip the drain pan: stap 11, afbeelding 1 van 2 Whirlpool Refrigerator Drain Pan Replacement, Unclip the drain pan: stap 11, afbeelding 2 van 2
    • Use a flathead screwdriver, or a similar tool, to pry up the metal clip from the back of the drain pan.
  12. Whirlpool Refrigerator Drain Pan Replacement, Reposition the wiring harness: stap 12, afbeelding 1 van 3 Whirlpool Refrigerator Drain Pan Replacement, Reposition the wiring harness: stap 12, afbeelding 2 van 3 Whirlpool Refrigerator Drain Pan Replacement, Reposition the wiring harness: stap 12, afbeelding 3 van 3
    • Pull the wiring harness straight out of the chassis until you can access the drain pan.
  13. Whirlpool Refrigerator Drain Pan Replacement, Peel the tape: stap 13, afbeelding 1 van 3 Whirlpool Refrigerator Drain Pan Replacement, Peel the tape: stap 13, afbeelding 2 van 3 Whirlpool Refrigerator Drain Pan Replacement, Peel the tape: stap 13, afbeelding 3 van 3
    • Peel the tape off the front metal clip attached to the drain pan.
  14. Whirlpool Refrigerator Drain Pan Replacement, Unclip the drain pan: stap 14, afbeelding 1 van 3 Whirlpool Refrigerator Drain Pan Replacement, Unclip the drain pan: stap 14, afbeelding 2 van 3 Whirlpool Refrigerator Drain Pan Replacement, Unclip the drain pan: stap 14, afbeelding 3 van 3
    • Use your fingers to release the metal clip on the front of the drain pan.
    • Fold the metal clip so that it lays flat on the floor of the chassis.
  15. Whirlpool Refrigerator Drain Pan Replacement, Remove the drain pan: stap 15, afbeelding 1 van 3 Whirlpool Refrigerator Drain Pan Replacement, Remove the drain pan: stap 15, afbeelding 2 van 3 Whirlpool Refrigerator Drain Pan Replacement, Remove the drain pan: stap 15, afbeelding 3 van 3
    • Pull the drain pan toward the front of the chassis to release any remaining clips.
    • Remove the drain pan.
Conclusie
Repair didn’t go as planned? Ask our Answers community for help.
Één andere persoon heeft deze handleiding voltooid.
nicO
15.945 Reputatie
89 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 69
Afgelopen 30 dagen: 311
Altijd: 11,875
