Ga door naar hoofdinhoud
Whirlpool Refrigerator Control Board Replacement
Wat je nodig hebt
  1. Whirlpool Refrigerator Control Board Replacement, Safety precautions: stap 1, afbeelding 1 van 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Control Board Replacement, Unfasten the dispenser panels: stap 2, afbeelding 1 van 2 Whirlpool Refrigerator Control Board Replacement, Unfasten the dispenser panels: stap 2, afbeelding 2 van 2
    • The dispenser panel screws are located under the dispenser as if you're looking up into the dispenser tube (where the ice cubes and water come out).
    • Remove the screw(s) securing the two dispenser panels.
  3. Whirlpool Refrigerator Control Board Replacement, Remove the dispenser panels: stap 3, afbeelding 1 van 3 Whirlpool Refrigerator Control Board Replacement, Remove the dispenser panels: stap 3, afbeelding 2 van 3 Whirlpool Refrigerator Control Board Replacement, Remove the dispenser panels: stap 3, afbeelding 3 van 3
    • Pull the dispenser panels straight down to separate them from the chassis.
    • Remove the dispenser panels.
  4. Whirlpool Refrigerator Control Board Replacement, Unfasten the control board: stap 4, afbeelding 1 van 1
    • Remove the screw(s) securing the control board.
  5. Whirlpool Refrigerator Control Board Replacement: stap 5, afbeelding 1 van 3 Whirlpool Refrigerator Control Board Replacement: stap 5, afbeelding 2 van 3 Whirlpool Refrigerator Control Board Replacement: stap 5, afbeelding 3 van 3
    • Tilt the bottom of the control board away from the chassis to release its clips.
    • Pull straight down to separate the control board enough to access its connectors.
  6. Whirlpool Refrigerator Control Board Replacement, Disconnect the control board: stap 6, afbeelding 1 van 3 Whirlpool Refrigerator Control Board Replacement, Disconnect the control board: stap 6, afbeelding 2 van 3 Whirlpool Refrigerator Control Board Replacement, Disconnect the control board: stap 6, afbeelding 3 van 3
    • Disconnect the connectors attached to the control board.
  7. Whirlpool Refrigerator Control Board Replacement, Remove the control board: stap 7, afbeelding 1 van 1
    • Remove the control board.
Conclusie
Repair didn’t go as planned? Ask our Answers community for help.
Één andere persoon heeft deze handleiding voltooid.
nicO
15.945 Reputatie
89 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 24
Afgelopen 30 dagen: 194
Altijd: 4,990
