Ga door naar hoofdinhoud
Whirlpool Refrigerator Auger Motor Replacement
Wat je nodig hebt
  1. Whirlpool Refrigerator Auger Motor Replacement, Safety precautions: stap 1, afbeelding 1 van 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Auger Motor Replacement, Open the doors: stap 2, afbeelding 1 van 3 Whirlpool Refrigerator Auger Motor Replacement, Open the doors: stap 2, afbeelding 2 van 3 Whirlpool Refrigerator Auger Motor Replacement, Open the doors: stap 2, afbeelding 3 van 3
    • Depending on your repair, open one or both doors.
  3. Whirlpool Refrigerator Auger Motor Replacement, Remove the icemaker tray: stap 3, afbeelding 1 van 2 Whirlpool Refrigerator Auger Motor Replacement, Remove the icemaker tray: stap 3, afbeelding 2 van 2
    • Pull the icemaker tray completely out of its slot in the chassis.
  4. Whirlpool Refrigerator Auger Motor Replacement, Unfasten the icemaker assembly: stap 4, afbeelding 1 van 2 Whirlpool Refrigerator Auger Motor Replacement, Unfasten the icemaker assembly: stap 4, afbeelding 2 van 2
    • Remove the screw(s) securing the icemaker assembly.
    • The second photo shows the potential screw locations in a removed icemaker assembly.
  5. Whirlpool Refrigerator Auger Motor Replacement, Reposition the icemaker assembly: stap 5, afbeelding 1 van 3 Whirlpool Refrigerator Auger Motor Replacement, Reposition the icemaker assembly: stap 5, afbeelding 2 van 3 Whirlpool Refrigerator Auger Motor Replacement, Reposition the icemaker assembly: stap 5, afbeelding 3 van 3
    • Pull the icemaker assembly off its slot in the chassis.
    • Let the assembly hang to access its connectors.
  6. Whirlpool Refrigerator Auger Motor Replacement, Disconnect the icemaker assembly: stap 6, afbeelding 1 van 3 Whirlpool Refrigerator Auger Motor Replacement, Disconnect the icemaker assembly: stap 6, afbeelding 2 van 3 Whirlpool Refrigerator Auger Motor Replacement, Disconnect the icemaker assembly: stap 6, afbeelding 3 van 3
    • Disconnect any connectors attached to the icemaker assembly.
  7. Whirlpool Refrigerator Auger Motor Replacement, Remove the icemaker assembly: stap 7, afbeelding 1 van 1
    • Remove the icemaker assembly.
  8. Whirlpool Refrigerator Auger Motor Replacement, Unfasten the icemaker auger assembly: stap 8, afbeelding 1 van 1
    • Remove the screw(s) securing the icemaker auger assembly.
  9. Whirlpool Refrigerator Auger Motor Replacement, Reposition the icemaker auger assembly: stap 9, afbeelding 1 van 3 Whirlpool Refrigerator Auger Motor Replacement, Reposition the icemaker auger assembly: stap 9, afbeelding 2 van 3 Whirlpool Refrigerator Auger Motor Replacement, Reposition the icemaker auger assembly: stap 9, afbeelding 3 van 3
    • Pull the icemaker auger assembly off of its slot in the chassis.
  10. Whirlpool Refrigerator Auger Motor Replacement, Disconnect the icemaker auger assembly: stap 10, afbeelding 1 van 3 Whirlpool Refrigerator Auger Motor Replacement, Disconnect the icemaker auger assembly: stap 10, afbeelding 2 van 3 Whirlpool Refrigerator Auger Motor Replacement, Disconnect the icemaker auger assembly: stap 10, afbeelding 3 van 3
    • Disconnect any connectors attached to the icemaker auger assembly.
  11. Whirlpool Refrigerator Auger Motor Replacement, Remove the icemaker auger assembly: stap 11, afbeelding 1 van 1
    • Remove the icemaker auger assembly.
  12. Whirlpool Refrigerator Auger Motor Replacement, Remove the auger fin: stap 12, afbeelding 1 van 3 Whirlpool Refrigerator Auger Motor Replacement, Remove the auger fin: stap 12, afbeelding 2 van 3 Whirlpool Refrigerator Auger Motor Replacement, Remove the auger fin: stap 12, afbeelding 3 van 3
    • Twist the auger fin clockwise until it separates from the assembly.
    • Remove the auger fin.
  13. Whirlpool Refrigerator Auger Motor Replacement, Unfasten the grounding wire: stap 13, afbeelding 1 van 1
    • Remove the screw(s) securing the grounding wire.
  14. Whirlpool Refrigerator Auger Motor Replacement, Unfasten the auger motor: stap 14, afbeelding 1 van 1
    • Remove the screw(s) securing the auger motor.
  15. Whirlpool Refrigerator Auger Motor Replacement, Disconnect the auger motor: stap 15, afbeelding 1 van 2 Whirlpool Refrigerator Auger Motor Replacement, Disconnect the auger motor: stap 15, afbeelding 2 van 2
    • Use needle nose pliers, or your hands, to disconnect the grounding wire from the auger motor.
  16. Whirlpool Refrigerator Auger Motor Replacement: stap 16, afbeelding 1 van 3 Whirlpool Refrigerator Auger Motor Replacement: stap 16, afbeelding 2 van 3 Whirlpool Refrigerator Auger Motor Replacement: stap 16, afbeelding 3 van 3
    • Disconnect the connectors attached to the auger motor.
  17. Whirlpool Refrigerator Auger Motor Replacement, Only the auger motor remains: stap 17, afbeelding 1 van 1
    • You're now left with the auger motor.
  18. Whirlpool Refrigerator Auger Motor Replacement, Meter the auger motor: stap 18, afbeelding 1 van 1
    • If you own a multimeter, you can test your auger motor's resistance.
    • A range between 5-50 Ω is acceptable.
Conclusie
Repair didn’t go as planned? Ask our Answers community for help.
nicO
15.927 Reputatie
89 handleidingen geschreven
Global Fixers Lid van Global Fixers
Community
45 Leden
702 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 81
Altijd: 1,512
